88 na no pulse on rear injector
Old Oct 19, 2008 | 05:31 PM
GB7's Avatar
GB7
so my son drags this 88 fc home. its been sitting up 2 or 3 years, we clean the gas tank ,new filters ,plugs and poof cranks and runs on front rotor . I have compression and spark on rear but no injector pulse . I'm thinking ecu [anyone?]
Old Oct 19, 2008 | 05:47 PM
KhanArtisT's Avatar
Former FC enthusiast
It could be the ECU, but unless you have a spare to test it with you can rule out the injector or wiring by:
*checking for 12v at the rear rotor primary injector pin to rule out a wiring problem. See FUEL AND EMISSIONS section in FSM (FAQ) for the pins.
*remove the intakes and apply 12v/Ground to injector and listen for a click. Then pressurize the fuel system (jump yellow test connector), key ON and take note of the spray pattern if any.
Old Oct 19, 2008 | 06:00 PM
GB7's Avatar
GB7
yeah did the 12 volts to the injector and it fires , and have voltage at the injector plug . so i'm still thinking ecu
Old Oct 19, 2008 | 11:08 PM
KhanArtisT's Avatar
Yeah I would say its the ECU then.
Old Oct 20, 2008 | 02:48 AM
CrazyJason's Avatar
Are you checking the primary rear injector or secondary rear injector? I think the secondaries dont fire on start up. Also, make you plug in the injector clips to the right injectors. Otherwise you will be punching yourself in the face later on...
Old Oct 20, 2008 | 05:26 AM
HAILERS's Avatar
HAILERS
Buy a LED from Radio Shack. Put the LED red lead into the small plugs wire on the far left that is black/white. Put the other LED lead into the fuel injector wires socket.
Crank the engine over. The LED will blink if the injector and ECU are working.
Clarification: you would bare the ends of the LED wires and shove them up the backside of where the respective wires enter the plug so they would make contact with the wire/contact inside the plug. It is the small plug on a series four ECU.
Attached Thumbnails 88 na no pulse on rear injector-fuelinjector.jpg   88 na no pulse on rear injector-ledwires.jpg
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
