brake problem need info
Old Oct 18, 2008 | 04:35 PM
rosado-rotary's Avatar
i've got a 88 turbo 2 with abs. i don't know what in the world is wrong with this damn car if i drive around for maybe ten minutes my wheels want to lock up and when i let go of the gas instead of it rolling it comes to a dead stop.then its a pain to get it moving i have to boost the car to 10 pounds just to get into the driveway and when i look at the calipers they all are smoking.but if i let the car sit for a little while it rolls on its own again no i've searched and have replaced the check valve and i also heard that a bad abs unit will cause this that's why mazdatrix sells the abs delete kit.my abs doesn't come on at all the light is on.but my brother was wondering if it was the brake proportion valve any info would help i need this car to run again i just dumped money into it and then this happens
Old Oct 19, 2008 | 03:19 AM
is this a common problem with the abs cars?
Old Oct 19, 2008 | 06:41 AM
Turbonut's Avatar
Most use the ABS delete kit just to clean up the engine bay, or because of an ABS component failure that is very costly.
I would not think this a ABS problem as the pump has separate valves for all 4 wheels. Usually it's contaminated calipers that cause the piston(s) to stick and hold the pads against the rotors, or sticking guide pins. At times the flexible rubber brake lines will break internally not allowing the fluid to return to the MC quickly. This is why over time the fluid will bleed back and make the car driveable once again. This again does not happen to all 4 wheels at one time though.
As you have replaced the check valve, next time it happens, pull the vacuum hose off the brake booster just to be certain and see what happens. Clogged master cylinder return port possibly, and the only other part that comes to mind would be the rod adjustment from the pedal to the MC, but if untouched, it's not going to change, so make certain there is pedal play.
Old Oct 19, 2008 | 07:22 AM
when i pull off the hose to the booster air comes out and the wheels free up i think it might be the booster but i don't really know.i just ordered a abs delete kit this morning
Old Oct 19, 2008 | 08:57 AM
Turbonut's Avatar
Not the ABS. There is vacuum in the booster, front and rear of the diaphram, but when the brakes are applied, vacuum is closed off on the back and atmosphic air then enters the back of the booster while vacuum is pulling on the front, When you release the pedal vacuum should be able to return to both sides. It seems that this is not able to happen, so the booster holds pressure against the master cylinder.
My best guess.
Old Oct 19, 2008 | 03:26 PM
so does this mean i need a booster
Old Oct 24, 2008 | 11:12 PM
misterstyx69's Avatar
Retired Moderator, RIP
This sounds like the Check valve in the line is not present from the Booster to the Vacuum source.You may be able to get Brakes,but the darn thing still sees vacuum and continues to allow the booster to put the brakes on..MY guess,BAD check valve.
Old Oct 25, 2008 | 06:50 PM
i found the problem it was the booster after all
Queppa
Nov 18, 2024 03:47 AM
djritz
Aug 25, 2015 02:46 PM
fastsaab
Aug 19, 2015 11:42 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 13, 2015 11:19 AM
