Car Idles ,but wont start
Old Oct 17, 2008 | 05:56 PM
vr4much's Avatar
third gen rx7 suddenly stopped starting
I don't drive the car, but start it ones in a while let it run for 2-3 mins.
Today i started it ran for a bout a 3 mins then it slowly died ( sluggishly) when i try to start it again wants to start but is not quite catching something (exact same as if your starting your car in the morning below 30 degrees in winter.
The car is parked slanted downhill and i do have a quarter tank of gas in there.
The car also recently started doing this, what does this mean ? ( the black exhaust resedue on the back bumper from the exhaust), does not actually blow black or any color smoke from exhaust though
Old Oct 17, 2008 | 06:03 PM
vr4much's Avatar
k i think i know what it might be,
i remember when the car used to start it was very sluggish (felt like it was goina die, but did not) also i remember when it's stationary (neutral) i gave it a bit of gas and after that it felt like it did not hold the same idle sound as it should
Old Oct 17, 2008 | 10:47 PM
vr4much's Avatar
i found the exact same problem, here is the video please listen
http://www.youtube.com/watch?v=QG1Ko...eature=related
Old Oct 18, 2008 | 02:32 PM
vr4much's Avatar
did I flood my engine ??
this morning the idle sounds even weaker than yesterday
Old Oct 18, 2008 | 02:44 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
you need to run the car for longer then 3 mins at a time. that is not long enough to get the car to operating temperature. you probably have carbon build up all over and the plugs are probably fouled. change the plugs and do the deflood procedure if necessary. Then get the car fully warmed up and take it for a hard run. maybe even do the steam clean method to clean up everything. And in the future make sure everytime you start the car you let it run till its fully warmed up.
Old Oct 18, 2008 | 02:56 PM
thewird's Avatar
I can almost guaranteed say its the plugs. There is also a possibility your turbo oil seals are leaking.
You run your car 3 minutes once and a while??? Dude your chambers are probably so fouled with carbon it isn't even funny. You need to let it run for like 10-20 minutes and then give it some slow revs.
thewird
Old Oct 18, 2008 | 03:17 PM
Azcamel's Avatar
Put it in her butt
change the plus and unflood the engine as other mention, then take it out and red line it a few times, these engine can use the high rpms to clean it out.
Old Oct 18, 2008 | 03:35 PM
vr4much's Avatar
eh i have a lot to learn about the rotary.. I'm used to soarers and 3000gt's
I also thought changing plugs would be agood idea since when i changed the oil it was charcoal back (assuming it hasn't been maintananced in a looong time)
is this the procedure for de-flood ?
http://courseware.ee.calpoly.edu/~fd...7_restart.html
Old Oct 18, 2008 | 03:55 PM
thewird's Avatar
If you can get the car to start, you don't need to go through any deflood procedures.
Change the plugs, let it fully warm up (10-20 minutes) and go for some hard runs to clean it up. And never start the car and only let it run for 3 minutes, that equals not good things.
Note: Simple deflood procedure would be to unplug the EGI fuse and crank the car for 5 seconds. Then plug it back in and try to start the car again.
thewird
Old Oct 18, 2008 | 04:07 PM
MOBEONER's Avatar
It's finally reliable
yup the plugs,i run into this problem my self from time to time my since FD sits for weeks at a time without starting,change the plugs and she will go on...
Old Oct 18, 2008 | 04:28 PM
vr4much's Avatar
k thanks guys,
are NGK OEM plugs okay ?
Old Oct 18, 2008 | 04:47 PM
thewird's Avatar
NGK OEM plugs are more then fine. Make sure you have the stock 7 leading, 9 trailing heat ranges. Unless the car is quite a bit modified.
thewird
Old Oct 19, 2008 | 10:07 AM
Tim Benton's Avatar
FD title holder since 94
If it's modified to some extent (ie intake, cat-back, IC and a downpipe)- go with all 9's is the general idea.
Tim
Old Oct 19, 2008 | 07:23 PM
vr4much's Avatar
wow changing plugs on this is ridiculous, i guess previous owner tighten them to the ****. The old plugs were as dark as the oil change and has semi -oily tips.
The car started with a bit of gas, i redlined it a few times i guess its good now
thanks for help guys
Old Oct 20, 2008 | 02:31 PM
SWAT81's Avatar
8AN5H33
u should never warm your car up for only 3min... that's not even a warm up especially if you are not driving it and just letting it sit on the drive way. Make sure to warm up and idle for at least 15minutes if you don't drive it at least once a week.
Kyo
Apr 13, 2019 09:24 AM
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
alphawolff
Nov 17, 2015 05:57 PM
bb6guy
Aug 12, 2015 03:29 PM
