do i need a standalone for a BNR
Old Oct 16, 2008 | 02:11 PM
DriftN7's Avatar
Touging anyone
do i need a standalone or piggyback with a stage 2 BNR turbo? Thanks an advance
Old Oct 16, 2008 | 02:26 PM
need RX7's Avatar
Listen to King Diamond.
You won't need a full standalone, but you'll definitely need an SAFC or RTek or something similar, since you'll need more fuel with the BNR and a way to control it.
Old Oct 16, 2008 | 03:21 PM
Osirus9's Avatar
Jackstand Drifter
I would add a wideband and/or dyno tune to that list.
thats what i have though
Old Oct 16, 2008 | 05:25 PM
*TOUCH*'s Avatar
Project P --- Pedospeed
wideband+safc+rtek+bigger injectors. if you plan on upgrading further than your stage 2 later, just go ahead and get a full stand alone now. at least i would
Old Oct 16, 2008 | 06:08 PM
DriftN7's Avatar
Touging anyone
thanks for your help and replies.
Old Oct 16, 2008 | 06:27 PM
RotaryWeaponSE7EN's Avatar
Can you use the rtek and safc in conjunction?
Old Oct 16, 2008 | 07:40 PM
*TOUCH*'s Avatar
yes, but i dont know why you would. the rtek already has fuel maps (if you are using one of the injector combos that are "preset") and is completely adjustable. so lets say you are running 550cc prim. and 1000cc sec. although this is not one of the "preset" injector setups, you can set it to the 550/720 preset and manual lean out the a/f. as said above, depending on your ultimate goals you may just wanna upgrade to a full standalone. although with an safc you can control pretty much any size injectors, you have no control over timing. and although you can control both timing and fuel with the rtek, it still requires the use of the stock afm (or at least the map sesor if you choose that route, i believe it allows for more potential) and thus is pretty limited. i think the most i have heard of someone making on an rtek is around ~350rwhp. generally 400hp or more should go for a true standalone. but i have never owned or used an rtek, so i could be wrong on these facts.
Old Oct 16, 2008 | 07:45 PM
Don't skimp on this step, you obviously didn't with the BNRs go standalone and you will never regret it.
Old Oct 16, 2008 | 07:54 PM
*TOUCH*'s Avatar
also, look in the engine management section to get familiar with your options (safc and rtek sections are there as well) and see what you need/want in your ems if you choose that route
Old Oct 17, 2008 | 09:19 AM
Archangels's Avatar
- Make Haste -
piggy back, yes, infact i have an HKS FCON with GCC i can sell you, works perfect and does the job!...
SRTx781
Dec 19, 2015 07:30 PM
matty
40
Oct 6, 2015 09:13 PM
