Transmission Crossmember Help.
Old Oct 15, 2008 | 01:43 PM
Hanlok's Avatar
FL Transmission Crossmember Help.
I am resurrecting a 10thAE that was a stolen recovery. I purchased a JDM S5 swap to put in the car only to find that the transmission crossmember was taken along with everything else that was drivetrain related. My question is this:
Do the transmission crossmembers differ from Turbo to N/A and S4 to S5?
I have completed most of the body work and was going to be installing the
Old Oct 15, 2008 | 01:59 PM
87 t-66's Avatar
not a drifter
i have a spare if you need one. PM me.
Old Oct 15, 2008 | 02:44 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
The crossmember needs to be the same series as the trans.
Old Oct 15, 2008 | 02:57 PM
Rx-7fetish's Avatar
The Blue Blur
so an n/a s4 crossmember is the same as a turbo s4 crossmember but differs from s5 but s5 n/a is the same as turbo s5?
Old Oct 15, 2008 | 04:27 PM
Turbonut's Avatar
4 different crossmembers, 1 for each application
86-88 N/A
86-88 Turbo
89-91 N/A
89-91 Turbo
The Auto is the same for 86-91
As stated above, the crossmember must match the transmission.
Old Oct 15, 2008 | 07:01 PM
FC-Dan's Avatar
http://www.mazdatrix.com/g3.htm You can buy the crossmember there for a lot cheaper than the dealer (at least in my neck of the woods.)
Old Oct 16, 2008 | 10:09 AM
alexdimen's Avatar
TANSTAFL
You guys are forgetting one more thing. The crossmember not only has to match the transmission, but also the body between NA S4's and S5's.
S5 NA crossmembers have both mounting points parallel to the ground. The S4 has one mounting point parallel and one at an angle, so an S5 crossmember won't bolt up to the body.
Old Oct 16, 2008 | 11:31 AM
solareon's Avatar
having a blown out center bushing in a crossmember will cause the car to shake especially from low rpm take offs correct?
MILOS7
Oct 9, 2015 02:19 AM
rxlevi7
Sep 26, 2015 07:28 AM
