Need help with fan connectors.
Old Oct 12, 2008 | 04:44 PM
chemicool's Avatar
Can someone tell me or show me a pic of the fan connectors and which color wires from harness correspond with which color wires from the fan. I was a dumbass and assumed they would be the same and removed the stock connectors while trying to install my v mount. The colors from the fan are yellow, green, black, and blue. The colors from the harness are different. Thanks.
Old Oct 12, 2008 | 05:52 PM
Andrew.'s Avatar
The end of an era
Wiring diagram in the FSM, section Z I believe.
Old Oct 12, 2008 | 06:53 PM
chemicool's Avatar
I know I have the manual on a disk but I friggin misplaced it. I guess I'll take a look again. I like pics though just to make sure
Old Oct 12, 2008 | 10:43 PM
chemicool's Avatar
Well I looked at the wiring diagram for the fans and it is no help. The colors listed on the diagram do not match the colors I have. If anyone has anny pics or can tell me what wires match up I would appreciate it.
Old Oct 12, 2008 | 10:56 PM
IRPerformance's Avatar
Sponsor
Did you cut the harness side or the fan side? I usually mod the fan side. I can look at a car at the shop tomorrow.
Old Oct 13, 2008 | 10:35 AM
chemicool's Avatar
Both sides are cut. It's a Knightsports kit and it requires replacing connectors on both sides to use with their extension harness. I just (incorrectly) assumed the wires would be the same colors on both sides. If you get a chance I would appreciate it. The car is a 94. I don't know if earlier models were different?
Old Oct 13, 2008 | 11:01 AM
Sponsor
blue-yellow, green-white, yellow-black, black- blue/w orange tracer. The first color is the fan side, the 2nd is the harness side. You cut the wires so close you can't see the colors? I always leave an inch or two of wire in case I need to reuse the connector.
Old Oct 13, 2008 | 03:10 PM
chemicool's Avatar
Thanks man! You are a pal. No I can see the wires. I removed the plastic connectors so I could attach new plastic connectors but I didn't pay attention to which wires from fan side corresponded to body harness side. I assumed they would be the same I guess. I think what you told me is all I need though.
atticus_jay
Interior / Exterior / Audio
Oct 23, 2015 11:16 AM
