Power FC Oct 11 2008 Updated Base Maps
Old Oct 11, 2008 | 11:34 PM
BDC's Avatar
BDC
BDC Motorsports
Hey guys, I posted up a link in another thread but thought I'd just make one here instead. I've updated some of my basemaps in the past few days. I zipped 'em up and uploaded 'em to my website. They fit a varying number of injector/engine combinations. They're available to the public and hopefully it can help some folks get their cars running. Some of them are derived from actual tuned setups and some aren't although all of the ignition maps are written completely by hand and are not copied from any other maps. Quite frankly, the base maps out there (atleast on the spark advance end) are complete garbage. Hopefully these will help but don't load one in and go run the car at the drag strip an hour later expecting everything to be 100%. As any other base map, it's intended to get a car started and running only and that's it.
Any comments or questions are welcome.
http://bdc.cyberosity.com/v/Technica...d/PowerFCMaps/
B
Old Oct 12, 2008 | 12:35 AM
FC3S Murray's Avatar
5 and counting.
Thanks man!
Old Oct 13, 2008 | 06:34 PM
rx72c's Avatar
Top Answer: 1
how do we know what map sensor each map is for?
or are they all to suit factory fd map sensor?
by the way youve done an awesome job. good stuff.
Old Oct 13, 2008 | 11:47 PM
BDC's Avatar
BDC
BDC Motorsports
Thanks my man. In each file under the Settings 5 tab, I list some notes that give the particulars of each setup. Part of those details is the MAP sensor type and its offset/scaling.
B
Old Oct 14, 2008 | 01:45 AM
rx72c's Avatar
Top Answer: 1
Ok cool. thanks mate.
Old Oct 14, 2008 | 09:35 PM
mono4lamar's Avatar
In the burnout box...
Hey Brian, its definitely a great service you're providing here. I would also like to point out you might want to specify the map sensor used. I saw option 4 selected on one of them. This will definitely throw a map newbie for a loop...
Old Oct 15, 2008 | 12:03 AM
BDC's Avatar
BDC
BDC Motorsports
Thanks my man. What specific map was it? Did I screw something up in my notes or something??
B
Old Oct 16, 2008 | 09:32 PM
5 and counting.
Here you are Brian. Thank you.
Old Oct 20, 2008 | 05:07 AM
Speedworks's Avatar
Hy Brian,
Do you possibly have a map for a streetported engine, stock injectors and full non seq turbo's? running stock boost
Thx
Old Oct 23, 2008 | 11:51 AM
BDC's Avatar
BDC
BDC Motorsports
Howdy, the 550850_modifiedzs.dat file in there ought to work IIRC the settings. Check the zip file then swing over to Settings 5 tab in the Datalogit software and eyeball the notes in the bottom right.
B
Old Oct 23, 2008 | 12:03 PM
Speedworks's Avatar
Thanks, I figured it out in the meanwhile :-)
I just took out the O2 control as I'm using a WB
Old Oct 23, 2008 | 03:38 PM
BDC's Avatar
BDC
BDC Motorsports
Roger. Let me know if that map works for you or if there's anything I need to modify.
B
Old Oct 23, 2008 | 08:27 PM
arghx's Avatar
rotorhead
BDC,
I like that you are posting this stuff. I think some tuners are unnecessarily guarded about their maps. The kind of people who are looking for basemaps are either
1) just trying to get the car started to get to an actual professional
2) going to tune it themselves anyway.
people take their car to a professional in part because they want piece of mind. It's similar with stock brokers/investment advisors. You could do some research and manage your investments yourself while maybe asking a few professionals for some advice. But in the end people go to professional investment advisors just to feel like a weight is off their shoulders and that they're being taken care of.
Old Oct 24, 2008 | 09:49 AM
Aeka GSR's Avatar
as far as using a stock map sensor with a 3 bar base map, do I just need to adjust the scaling and settings?
Old Oct 24, 2008 | 10:29 AM
BDC's Avatar
BDC
BDC Motorsports
Yep just select the other map sensor in Settings 3 tab for 35046 3947 or whatever those numbers are IIRC. I'm not going to guarantee that it'll work as those maps for their load points are made specifically for 2-bar and 3-bar maps respectively. I'd use the map made for whatever map sensor setup it is. The P11-P20 load points are re-done for 3-bar sensors.
B
Old Oct 24, 2008 | 10:33 AM
BDC's Avatar
BDC
BDC Motorsports
Originally Posted by arghx
BDC,
One thing I don't like is the idea of some ***** taking my data, sticking it on a car, and claiming it as their own, effectively stealing the many months of tuning different cars and research I've done. That's the problem with data like this no matter the EFI system; someone can yank it and use it. But, that's just the risk that has to be taken anyways as any car can have a laptop or PC w/ the software hooked up to it and the map yanked off easily. So it's kind of one of those things ya have to shrug at I guess. I hope these maps though can help some folks and hopefully they'll remember me once they get their cars started.
B
Old Oct 24, 2008 | 05:58 PM
twisted7's Avatar
Jake
Great service! too bad you are texas. That is one hell of a drive. Want to come to me haha .
BTW you do very good port work.
Hey in your map for the 8501680 HBPFD3s_ZS you have for Setting 5 for the Secondary injector listed as 1500 instead of 1680?
Also the F/C (AE/E.L/A/C) - are all set to 8000rpm... Just curious as to why you dont have the fuel cut going on during decel?
Old Oct 25, 2008 | 09:46 AM
BDC's Avatar
BDC
BDC Motorsports
Ah, on the bridgeport maps I do not use the fuel cut on decel because when the motor decels back down to a configured RPM (say 1700rpm for example), the car will burp and lurch forward and not respond well. I've never really used it on the bridgeports; the overlap has a negative effect.
B
Old Jun 24, 2013 | 12:51 AM
MoePwr's Avatar
Ballin!
the page isn't up. does this still exist? im looking for a base map for my full bridgeported motor
24seven_dada
20
Nov 10, 2018 12:03 PM
Sandro
3rd Gen General Discussion
24
Dec 30, 2017 03:35 PM
