stuck in gear
Old Oct 9, 2008 | 10:11 PM
turboIIrotary's Avatar
stuck in gear
my transmission is stuck in gear and i don't know why.
i was pulling the engine out of one car and putting it into another everything was working fine before the pull the transmission shifted smoothly.
i take the shifter out and remove the engine from the car then when i had the engine on the ground in my garage i put the shifter back in and i must of shifted it into one of the top gears 1,3,5.
now when i installed the engine into the new car it is stuck in gear and i can not get it out i haven't started the car yet but i can't tighten my driveshaft becuse the transmission is stuck in gear.
Old Oct 9, 2008 | 10:14 PM
Smitter's Avatar
94 Single Turbo FD
so the transmission is stuck in gear and the shifter is removed?
can u not reinstall the shifter?
Old Oct 9, 2008 | 11:06 PM
i put the shifter back in but it won't move anywhere it is in 1,3,or 5 one of the top gears and stuck it won't go into neutral or anything
Old Oct 10, 2008 | 12:49 AM
Smitter's Avatar
94 Single Turbo FD
is it possible that u did a really shitty job aligning the clutch before install the tranny, i had a problem similar once, i couldnt get my car into gear after installing my motor, ended up having to drop the tranny and realigning the clutch,
doesnt make much sense when i think about it now though
Old Oct 10, 2008 | 01:04 AM
i never removed the tranny from the engine i pulled both of them together that is why im confused it just got stuck out of no where.the tranny is already in a gear it is in either 1,3,or 5 and won't come out of it.
Old Oct 10, 2008 | 01:12 AM
Smitter's Avatar
94 Single Turbo FD
**** man, u got me stumped, are u sure the slave cylinder is in the clutch fork, u woulda had to reinstall that. even still it should come outta gear. i would cowboy that bitch outta there if i knew everything else was in check.
Old Oct 10, 2008 | 01:23 AM
the clutch is working i can push the clutch and it will be all normal its just like im in gear all the time and it won't come out of it.
Old Oct 10, 2008 | 02:35 AM
Hot.Damn.'s Avatar
My friend had a similar prob, his was the gear selector (If I remember correctly) just came apart. He needed a clutch anyways so he had that swapped out and they reassembled that as well and its been good as new since.
Good luck, hope its a easy fix
Old Oct 10, 2008 | 04:05 AM
dgeesaman's Avatar
Can you move the shifter through the gear positions at all? If so, which ones?
It sounds like one of the gears shifted into position but the shift selector didn't put it there. Unbolt the extension housing from the tranny (drain oil first) and make sure all 3 select forks are in the neutral position.
Dave
Old Oct 10, 2008 | 03:34 PM
nope i cant move in anywhere it stuck forward i will take it apart and check it out.
Old Oct 11, 2008 | 03:35 PM
cptpain's Avatar
Torqueless Wonder
you must have not reinstalled the shifter the correct way.
i have done this many times on motor swaps on 240's and my own 1st and 2nd gens.
look at where the pivot on the shifter goes. it should slide right into a cup looking thing
Old Oct 11, 2008 | 11:11 PM
it is in right it is kinda hard to put it in wrong i drove it around and it is stuck in first the shifter doesnt move at all.
Old Nov 27, 2008 | 07:24 AM
air_n_water's Avatar
Transmission stuck in gear
I have a simliar problem. All of a sudden without any sign of a problem, the transmission was stuck in a high gear. Releasing the clutch stalls the engine. With trans in neutral, releasing the clutch the car backs up (in reverse). I can shift to 1 and 2, 5 and R, but not 3 and 4. Any one have an idea what it could be?
Old Nov 27, 2008 | 11:06 AM
sereneseven's Avatar
Dave
+1 most likely its the 5th/rev the spring on the 5th/rev rod can over throw the shift fork when it is shifted out of rev without the shifter in place or if the bushing on the bottom of the shifter is worn out causing the selector rod to get stuck in the N gate while the 5th/rev shift rod is in 5th. Its may be easier to pull the pan rather than the tail housing. the 5th/rev rod is the farthest one of the three towards the drivers side side. you should be able to pop it back into N with a small pry bar or long screw driver.
Old Nov 27, 2008 | 01:20 PM
MR_Rick's Avatar
Planning my come back
That is exactly what happen to me. The only problem is that I forced it out. The consequences were not reverse and fifth was WAAAAAYYYYYY to the right.
Old Sep 23, 2010 | 09:19 PM
XLR8's Avatar
I bumped this thread because the exact same thing has happened to me. There's good info here so I felt no need to create a new thread.
Received a rebuilt tranny in the mail without a shifter. Installed it, with my B&M shifter in place.
With the shifter in neutral, it feels normal, but the drivetrain still spins. Can't shift into 1st, 5th, or Rev. Clutch is assembled correctly & bled. Push the clutch in & the pressure plate spins freely as it should.....
I will be pulling the pan this weekend as recommended above.... But I don't know much of what I am looking for. I will add that I know the tranny is good. Bought it from a reputable guy .
Any help would be appreciated.
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
subeone
Sep 24, 2015 09:58 PM
