3" 5 bolt turbo flange question
Old Oct 9, 2008 | 02:59 PM
Pourke's Avatar
I searched and maybe i'm searching for the wrong thing but I have a precision p54 turbo and it has a 5 bolt flange on the exhaust. I have a 4 bolt flange on my 3 inch down pipe so I'm cutting it off and welding a 5 bolt onto the 3" down pipe.
Question is:
Do they make 5 bolt 3" flanges? I can only find 2 1/2
Does it matter if I weld stainless dp to non stainless flange? I can't find a stainless one.
Old Oct 9, 2008 | 03:10 PM
ChrisRX8PR's Avatar
Question is:
Stainless welds great to regular mild steel. Use 308 or 309 welding rod/wire.
About the flange, you can always port it once you weld it
Chris
Old Oct 9, 2008 | 03:35 PM
mono4lamar's Avatar
In the burnout box...
They should. They tend to be called "Ford" style. I remember on my turboed MX6 I ran a Precision sc61. Do you know if your turbo is a t3 flange?
Old Oct 9, 2008 | 03:38 PM
mono4lamar's Avatar
I found a 5 bold "Ford" style with 3" v band welded onto it. Here's a link... http://cheapturbo.stores.yahoo.net/new3instainv.html
Old Oct 9, 2008 | 04:26 PM
RacerXtreme7's Avatar
NASA geek
Thats basically a 60-1 or T04E 60trim sized compressor popular with the Grand National guys. (I assume that was a typo, its a PT54, not a p54). Its a T4 turbine, but it comes with small t3 inlet turbine in a .63, or .85 A/R. Thats pretty damn small for a rotary. Is this turbo for a rotary? If so, I'd advise keeping your money for that flange your looking for and invest in a real T4 turbine housing with a v-band.
~Mike..................
Old Oct 9, 2008 | 06:57 PM
Smitter's Avatar
94 Single Turbo FD
if your welding any flanges, get the v-band ones, they will save u time, frustration, and anger not having to bolt the dp to the turbo, bolt ons are a nightmare.
i even have the 3" v-band flanges i could send your way
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
