RETed .....
Old May 12, 2002 | 09:37 PM
Anderson's Avatar
RETed .....
Hey I had a thread a couple day ago about using an N326 ECU (86-87 NA) on an 88 GTU which uses the N327, for about a week.
You said there were swapable, but you also mentioned injector recistance.
I jsut stumbled accros this post
https://www.rx7club.com/forum/showth...threadid=72980
where it talks about what eyars had which injectors and such.
What exactly is the diff between thsoe injector (Referign to the 2 2nd gen N/As.
Also would it still be ok to use the N326 ECU on my car??
Thx for any input.
Old May 13, 2002 | 01:00 AM
hypntyz7's Avatar
Im not reted, but...
The injector resistance thing was due to teh wiring harness adn injectors only...the ecu's saw the same thing, regardless of which setup the injection ran.
In short, you can run any 86-88 ecu in any other 86-8 car(na's). I have done it before many times with no ill effects. BTW I have plenty of spare ecu's if you need one, $40 each.
Old May 13, 2002 | 04:03 AM
RETed's Avatar
Re: RETed .....
hypntyz7 has given a good reply, but I'll throw in my 2&#162 anyways...
Yep, fuel injectors changed impedence in the middle of 1987.&nbsp The "problem" is that the engine wiring harness ALSO changed at the same time.&nbsp The ECU has no clue what it's firing, but it wants to see a 12-14&#937 impedence on all four fuel injector channels.&nbsp The earlier pre '87.5 engine harness has a plug-in "fuel injector resistor block" that up's the fuel injector impedence so the ECU is happy.&nbsp On later models, this resistance block is deleted, and Mazda went with high-impedence fuel injectors to compensate.
About 10&#937
Yes, it's not a problem - the ECU doesn't know what kinda of fuel injectors you're using due to the presence (or absence) of the resistance block.
/RANT ON
People, if you want to direct questions for me, I do read my PM's.&nbsp It is against Forum rules to be putting nicks int the subject header - I don't mind answering questions, but keep my name out of the subjects!&nbsp Also, give a GOOD description of the problem in the SUBJECT - that's what it's there for!&nbsp Lately, I have seen too many "I NEED HELP" or "I GOT A PROBLEM" type if subjects - I scan through way too many posts everyday.&nbsp I will NOT look at your posts if you put something vague like that in your SUBJECT header!
/RANT OFF
-Ted
Old May 13, 2002 | 04:51 AM
NZConvertible's Avatar
I'm a boost creep...
Originally posted by RETed
People, if you want to direct questions for me, I do read my PM's. It is against Forum rules to be putting nicks int the subject header - I don't mind answering questions, but keep my name out of the subjects! Also, give a GOOD description of the problem in the SUBJECT - that's what it's there for! Lately, I have seen too many "I NEED HELP" or "I GOT A PROBLEM" type if subjects - I scan through way too many posts everyday. I will NOT look at your posts if you put something vague like that in your SUBJECT header!
About time someone said all that...
Old May 13, 2002 | 12:03 PM
hypntyz7's Avatar
Kick his *** Ted!
wwarlick
Jun 14, 2002 09:34 PM
DK
May 21, 2002 08:43 PM
No7Yet
Mar 2, 2002 02:42 PM
jeff88
Aug 3, 2001 09:26 PM
