Rebuild & now now start
Old May 12, 2002 | 06:01 PM
Question Rebuild & now now start
85 12a. Rebuilt engine & mild street port. Removed rats nest & blocked off all nipples. Removed air pump & put on a blocking plate on carb & dual pulley to alternator. Engine is getting fuel.
All 4 plugs are sparking good.
Anyone got any suggestions to get my car back on the road, other than the major oil leak I had before, the engine ran strong although a little hard to start ie 3 or 4th start.
Old May 12, 2002 | 08:13 PM
Pele's Avatar
Right near Malloy
Double check all your vacuum blocks. Also you might not have goetten a good rebuild, compression check it.
You sure the dizzy got put back in right after the rebuild? It could be 180 Degrees off.
Old May 12, 2002 | 09:29 PM
Project84's Avatar
Open up! Search Warrant!
Just a rule of thumb.... when you do a bunch of mods, do one at a time, then start your car to see how it runs after each mod. If you do 10 mods and have 3 different problems after you start the car, its hard to guess what is wrong.
Old May 13, 2002 | 05:24 AM
yayarx7's Avatar
Are you Nucking Futs?
Sometimes when nothing else wants to work, I pull start the thing. I have had to resort to this once after an engine swap, and once after a carb swap. I do not know why, but it always eventually works when I drag her behind something for a few blocks
Old May 13, 2002 | 05:32 AM
Felix Wankel's Avatar
Super Newbie
A lot of times rebuilds are hard as hell to get started. I'd try a pull start too.
Old May 13, 2002 | 09:22 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
when i got my rebuild in (i did it) it was tuff to start, well i put in a new starter and wow what a diff. so make sure its spinning at a good rpm. also check the timing.
Old May 13, 2002 | 12:14 PM
Pele. After rechecking The dizzy was in wrong 180, having fixed that it still will not start, will do a compression test tonight, Anyone know how to turn off the fuel pump???
Old May 13, 2002 | 01:24 PM
I also just rebuilt mine and had a tough time getting it started, heres what you do. Pour alittle bit of oil down the carb just to build up the compression till it gets started. Its what ive heard alot of people have to do after a rebuild.
Old May 13, 2002 | 02:39 PM
Assume you mean MMO or ATF? Compression is around 80-85.
Old May 13, 2002 | 02:40 PM
Also how much oil?
Old May 13, 2002 | 03:10 PM
nimrodTT's Avatar
all aboard!
Just to clarify, if the dizzy was in wrong 180 degrees and the ratio of the dizzy to the eccentric shaft is 1:2 then your timing was off 360 degrees....hmmm...
Just pull the fuel pump fuse to shut it down.
Old May 13, 2002 | 06:35 PM
Pele's Avatar
Right near Malloy
You can also pull the connector under the driver's side storage bin to disable the fuel pump. Many people cut the wire and splice in a switch for anti-flood and security purposes.
Old May 13, 2002 | 06:43 PM
Just a little, maybee a tablespoon down both barells. this should work!
Old May 13, 2002 | 07:43 PM
Super Newbie
It will run 180 out. Take a look at the rotor button and cap, they are symmetrical.
Th0m4s
Feb 26, 2019 02:04 AM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
