Haltech question about staging.
Old Oct 2, 2008 | 08:13 PM
SirCygnus's Avatar
whats going on?
in the e6x, and the staging setup in the maps, how do the injectors fire?
do the primaries completely go offline and the 1600's go online? is it a smooth transition or is it a sudden transition?
Old Oct 4, 2008 | 06:10 PM
BASTARD's Avatar
the primaries fire first... then, when the load crosses the staging point all injectors fire...
tuning a smooth transition thru the staging points takes a lot of fine tuning especially in the light accleration and cruising zones
Old Oct 7, 2008 | 01:23 AM
BDC's Avatar
BDC
BDC Motorsports
Correct. That's why fuel curves on alot of the base maps downloaded here look like two ramps; a shorter one for about the first 11-13 load bars (with a vertical, dotted line shortly thereafter) then a longer one. The primaries are on only in this first ramp. At the staging point, they are brought down and fired in batch with the secondaries. Staging on the older systems is quite difficult as Bastard has mentioned when using large secondaries like 1680's.
B
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
