Megasquirt questiong on megasquirt I
Old Oct 1, 2008 | 06:51 PM
lonewolfrx's Avatar
im gettin a megasquirt I v3.0 . Does this only control fuel? or will it control fuel and spark? if its only fuel can i upgrade it to a vII?
Old Oct 1, 2008 | 08:10 PM
Craiger's Avatar
Hey man, welcome to the megasquirt world. The web will be your best friend for everything megasquirt, so get your reading glasses on and get going.
To answer your question, Yes MS1 extra code can control fuel and spark. This is the most common setup on a rotary, as it uses the factory CAS. If you didn't want to control spark, you would need something else to control that such as the dizzy ignition system from a 12a motor.
The MS2 extra code will also run a rotary now, but i use MS1 so I am not as familiar with that setup.
Good luck.
Craig
Old Oct 1, 2008 | 10:20 PM
lonewolfrx's Avatar
i see thanks. just wanted to know cause i reda somewhere that ms1 was fuel only and ms2 was fuel and spark. thats why i was asking
Old Oct 1, 2008 | 11:34 PM
lonewolfrx's Avatar
well on the ms.. it says ms130-c Megasquirt-I ECU .. does that run fuel and spark? it doesn't tell me extra code
Old Oct 2, 2008 | 09:13 AM
Aaron Cake's Avatar
Engine, Not Motor
Both MSI and MSII control fuel and spark. You will need to load MSnSE code to the MSI before you get spark control. MSII needs MS_Extra before you get rotary stuff.
Both boards require hardware mods to run our ignition and read our CAS.
These mods are covered in the FAQ.
Old Oct 2, 2008 | 02:31 PM
lonewolfrx's Avatar
well the previous owner of the ms said it was off an s4 tii. it even came with this http://i30.photobucket.com/albums/c3...s/PIC00311.jpg .
Old Oct 3, 2008 | 01:07 PM
muythaibxr's Avatar
MegaSquirt Mod
That's one of my plug'n play setups. It should be as it says: plug 'n play.
If the previous owner messed with the firmware or settings that are loaded, you may have to reset those, but other than that, it should just work.
The only thing that usually affects the plug 'n play ones is having bad grounds or other bad wiring in your stock harness.
Ken
Old Oct 5, 2008 | 12:26 AM
lonewolfrx's Avatar
oh ok. what are the other two wires for?
The Shaolin
Sep 14, 2015 07:50 PM
