turbonetic 62-1 any good?
Old 09-29-08, 04:08 PM
Leeroy_25's Avatar
Hi I have been looking at going single turbo on my FD3 and was planning to get a Holset.. However a tubonetics turbo has been offered to me.. it is the 62-1 0.96A/R. It is presumeably an older version as it does not have the ceramic roller bearings in it? and looks a little different. Will this be any good on my rotary and what bhp is it good for?? I am on stock ports currently but wil have plenty of fuel to offer it! What boost is this turbo capable of running?
Here is the turbonetics link.
http://www.turboneticsinc.com/produc...category_id=89
Thank you
Lee
Old 09-29-08, 06:03 PM
Will work for horsepower
Busted7's Avatar
Ive had good luck with mine!
Ported motor 20psi 500 h/p> turbonetics 62-1!
Should do easy 400 h/p if tunned well!
Old 09-30-08, 01:34 PM
Leeroy_25's Avatar
Thank you for the reply..
Am I correct in reading that there are two compressor sizes and two exhaust sizes options on this turbo? an A/R.63 and A/R .96??
Which are you runnning? Are you able to post a pic of your turbo for me to compare to the one I am looking at please?
Thank you
Lee
Old 09-30-08, 01:49 PM
Can I be the Emperor?
lt1_rx7's Avatar
i'm going to be running a T62-1 w/ .96 a/r. That turbo is available in a variety of exhaust A/Rs, but the .96 isn't available in divided housing.
Give me a few more weeks and I'll give you more info on how well it does on my car =]
Old 09-30-08, 01:57 PM
ChrisRX8PR's Avatar
Thank you
Lee
The 62-1 is available with many exhaust housing options, one of them being the .96A/R(preferred one on rotaries from what I have seen). I think the .63A/R you are also mentioning is way too small for use on a 13B. If I am not mistaken the compressor side of a 62-1 is 62mm inducer with a .70A/R unless you go with a Hi-Fi version(62mm inducer with a different A/R) but that wouldn't be beneficial to you.
Can anyone else elaborate?
Chris
Old 09-30-08, 02:07 PM
Back at it again!!
2Lucky2tha7's Avatar
My advice is to never go below a .81 a/r turbine housing.
Old 09-30-08, 02:15 PM
Leeroy_25's Avatar
I guessed the A/R 0.96 housing is the one required for the rotary. wondered if visually there is a noticable difference in the housing size so I can be sure I am getting the right one? or will if have something stamped into the housing? Is the Hi Fi compressor no good then?? I reckon it might be that? the inlet looks quite small compared to the one pictured on the turbonetic website. I can try and get a pic a post it up later.
Cheers
Lee
Old 09-30-08, 03:23 PM
ChrisRX8PR's Avatar
Cheers
Lee
The exhaust housing will have the A/R number casted into it near the 4 bolt flange on the rear. Also, I didn't say the HiFi wouldn't be any good, I said that going HiFi from a regular 62-1 wouldn't be beneficial to you. the HiFi squeezes the same compressor blade into a lower profile housing. The benefit is that it is smaller so it fits easier on some cars(RX-7 not being one of them, plenty of space) the trade off is 10% less flow. You can probably still get pretty good numbers on it though.
Chris
Old 09-30-08, 08:30 PM
JEROME's Avatar
Turbonetics makes turbos. For the money you're spending you would wiser to get yourself a GARRETT TURBO GT35R, 84 TRIM, 1.06 A/R. This system uses newer and better turbine technology. This one is good for 500hp. Please do not support old technology.
Old 09-30-08, 11:08 PM
Busted7's Avatar
The 62-1 i have is a .96 ar.
It has a 4'' inlet and a 3'' band clamp exhaust!
And as for old tech. i guess it is but 10.8 1/4 and 10.5 comeing without going above 500 h/p suites me fine!
Whats your track time?
Old 10-01-08, 06:54 AM
Mad Man
fritts's Avatar
Why would you want to use "OLD" proven technology. That just doesn't make sense. The 62-1 should outflow a GT35 at lower pressures.
Old 10-01-08, 03:00 PM
Leeroy_25's Avatar
Thanks guy's
I agree partly that this 'old' technology did us just fine before the new stuff came along!
anyhow. I am looking at this unit as it has come up cheap and has hardly been used!.
Here are a couple of pics of the unit. any ideas on what size she looks like as I am not getting an answers back yet! Also is that an on-cenre type housing I see?
If it is does that mean it's no good to fit the RX7?
Thank you
Lee
Old 10-01-08, 03:48 PM
Crash Auto?Fix Auto.
classicauto's Avatar
Looks to be an on-center T4 housing..somewhere in the 0.8X A/R range.
On-center isn't as efficient as a tang (tangential) housing and it will sit different on the manifold as a result. By sit different, I mean stick further away from the mani....but depending on the manifold setup it could fit. RX-7 engine bays have a pretty good real estate in the turbo area.
Old 10-01-08, 03:52 PM
BASTARD's Avatar
the turbine housing A/R should be cast into the housing... look inside the manifold flange area, you may need to clean off the carbon build up
Old 10-02-08, 10:36 AM
Back at it again!!
I used an on-center housing on my brother's car and I regret it
You can, however, buy a new tang housing--- divided or undivided and in different a/r's usually for around $150. Just make sure that it's for the correct trim wheel that this turbo has.
Old 10-02-08, 01:34 PM
Leeroy_25's Avatar
Sounds like it will be better to give it a miss! I thought it looked like an on centre!!
Cheers
Lee
82streetracer
08-23-15 09:28 AM
ChrisRX8PR
08-21-15 01:56 PM
Quick Reply: turbonetic 62-1 any good?
