How come I get low boost when engine is fully warmed up?
Old May 11, 2002 | 06:38 PM
Question How come I get low boost when engine is fully warmed up?
On hot days, after driving around traffic, I only get 5lbs. of boost in both turbos, and on cooler days (remember, only in SoCal) or when I've only been driving my car for around 15-20 minutes the car boosts properly. Is it a leak in the intercooler hose or elbow or something? Plus I think I have a stuck solenoid, cause sometimes I get boost and sometimes it seems to "forget". Thanks.
Old May 12, 2002 | 12:52 PM
Old May 12, 2002 | 08:02 PM
7-sins's Avatar
thats not paint....
Probably the solenoid you were talking about... I am sure they dont like the high engine bay temps.
Old May 12, 2002 | 08:43 PM
P'cola FD's Avatar
Hamado things my way!
The turbo control solenoid that is attched to the ACV has a tendency to fail once heat levels rise. I don't know if it will affect both turbos though. To find boost leaks try the test I posted here https://www.rx7club.com/forum/showth...ght=boost+leak
Old May 12, 2002 | 09:29 PM
Quik 93 FD's Avatar
going ls
sounds like an intercooler leak or a need to upgrade the intercooler soon, but i dunno
Old May 12, 2002 | 09:41 PM
2-Rotor's Avatar
Garaged
Low Boost
Sometimes i would have the same problem and if all checks out ok with the solinoids, then check the clamps on all the intercooler couplings. They have a tendancy to loosen up under heat and bleed off some of the boost. The coupling that has a problem with this is the rubber one right off the stock "Y" pipe.
Old May 13, 2002 | 01:16 AM
Thanks for the info guys, I'll check those out.
cristoDathird
28
May 30, 2019 08:47 PM
Kyo
Apr 13, 2019 09:24 AM
dkwasherexd
May 27, 2017 04:51 AM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
Wolf_
Aug 11, 2015 04:23 PM
