Replacing steering wheel
Old Sep 16, 2008 | 08:01 PM
pk-mofo's Avatar
Is it possible to install a steering wheel with an air bag? Lets say one of the stock FD steering wheels, is it possible to install it on an FC?
Old Sep 16, 2008 | 08:05 PM
87 t-66's Avatar
not a drifter
yes, but the air bag wont work...
actually, it might work if you have a vert. i believe the connectors are the same...they sure look like they are the same.
Old Sep 16, 2008 | 09:37 PM
clokker's Avatar
Cake or Death?
The wheel itself will fit nicely but nothing else will work without lots of fiddling.
Actually, getting the horn to function is pretty straightforward but the cruise and airbag would be more difficult- if even possible.
The problem is the slipring- the device that transfers the electrical connections to the rotating rim. The FD is totally different and a casual look doesn't show any way to adapt it.
Old Sep 16, 2008 | 09:50 PM
pk-mofo's Avatar
Tis' a shame.. What are your guys's thoughts about the fact that it has no airbag? Im planning to buy a '91 coupe and the fact that it has no airbags kind of worries me, not to the point that i dont want to buy the car anymore, but just little concerns.
Old Sep 16, 2008 | 09:56 PM
87 t-66's Avatar
not a drifter
i have a 91 vert w/ an airbag and i actually swapped it for an aftermarket wheel to get rid of it. no big deal IMO.
Old Sep 17, 2008 | 01:45 PM
freemanrx7's Avatar
^Hold On
What about putting in a conv FC airbag? Would that be a straight forward bolt on?
Old Sep 17, 2008 | 02:03 PM
clokker's Avatar
Cake or Death?
The wheel would probably fit but then you'd have to also retrofit all the associated electrics from the steering column AND the sensors etc. for the airbag as well.
Given the difficulties I'm having getting a cruise control installed, the airbag looks way too involved.
A rollcage and harness would probably be easier.
Old Sep 17, 2008 | 02:15 PM
dot_txt's Avatar
My car hates me
I'm glad my RX doesn't have an airbag. So long as I've got my seat belt on I feel safe enough. If the stock belt doesn't do it for ya you could always go with a cage and harness.
Th0m4s
Feb 26, 2019 02:04 AM
