sensor on back of water pump?
Old Sep 12, 2008 | 04:41 PM
rustbucket's Avatar
im pretty sure that the sensor on the back of the water pump with the green connector is connected correctly, but just under it to one side is what looks like a circular connector with a hole in the middle and i dont have it connected to anything, should it be??
Old Sep 12, 2008 | 10:04 PM
Icemark's Avatar
Found on Jspec motors, it is a sensor, but sounds like your's has the wires ripped out.
Old Sep 12, 2008 | 11:25 PM
rustbucket's Avatar
is it neccessary or can i just leave it unplugged, i have the emmissions removed and the omp removed anyways.
Old Sep 13, 2008 | 01:32 AM
FrankV702's Avatar
http://mazdatrix.com/pictures/o-elec...FanSensorB.jpg
Is that the sensor you're speaking of? If so, it's a fan switch sensor. I replaced that sensor with an aftermarket water temp sensor and gauge. No problems so far.
Old Sep 15, 2008 | 03:11 PM
rustbucket's Avatar
thats it exactly awsome, but what do you mean fan switch i dont have electric fans just a clutch fan.
Old Sep 16, 2008 | 11:24 PM
rustbucket's Avatar
any thoughts??
Old Sep 16, 2008 | 11:53 PM
NoDOHC's Avatar
Automatic = Power drain
Some have stock electric fans (my '91 does) they are in front of the radiator
Old Sep 17, 2008 | 11:12 AM
Icemark's Avatar
Turbos and some automatics have a factory supplemental electric fan.
And that sensor is not on the back of the water pump (as the thread title might suggest) on any of the S4 models, but rather it is on the thermostat neck, so next time you should include model and year.
streetlegal?
Mar 17, 2022 02:46 PM
FD7KiD
15
Feb 26, 2021 10:12 PM
sherff
Feb 24, 2019 12:09 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
FD7KiD
Aug 17, 2015 11:50 PM
