OMP lines.
Old Sep 4, 2008 | 11:16 PM
mjm4jc's Avatar
84 SE
OMP lines.
I was diddling around with the OMP lines today and thought that there has to be a better way to connect the OMP to the oil injectors. Is there anything wrong with using fuel hose in place of the plastic lines? I was thinking that a high quality fuel injected fuel hose with those little squeeze clamps should work fine. What do you guys think?
Thanks,
Mike
Old Sep 5, 2008 | 06:28 PM
trochoid's Avatar
Old Fart Young at Heart
Those little plastic lines last 25+ years, how long do you think rubber will last? The nice thing about them is the don't kink and stay where they are supposed to without vibrating and wearing holes due to vibration.
Old Sep 5, 2008 | 07:31 PM
mjm4jc's Avatar
84 SE
Yes, you are right that those plastic lines last a long time, but does not fuel hose last just as long? All my fuel hoses are 25 years old and look in better shape the OMP lines.
Old Sep 5, 2008 | 08:16 PM
wecycle's Avatar
OMP tubing
take a look at this thread
https://www.rx7club.com/showthread.p...&highlight=omp
Old Sep 5, 2008 | 08:39 PM
mjm4jc's Avatar
84 SE
Originally Posted by wecycle
I didn't read the whole thing, but I remember that thread fairly well. The tubing comes in straight sections, and I don't think I can use that considering the hard bends that are required. That's where fuel hose will clamps would be at an advantage. Just a thought :-)
Mike
Old Sep 6, 2008 | 01:01 AM
Percentage's Avatar
The PO put fuel lines on for my OMP lines and I haven't had a chance to replace them yet, but they work just fine. I don't see why it wouldn't be an issue.
Old Sep 6, 2008 | 10:53 AM
wecycle's Avatar
heat gun
You need to use a heat gun to put the bends in the polyethylene line.
Once bent they take a set to the shape you need.
Use of the wire ties or Oetiker clamps makes it very secure.
This also reduces the number of joints in the lines.
Note that the original lines are very small inside diameter. If you use larger diameter lines be sure to prefill them so oil will start flowing when you start the car.
Mike
Andrew7dg
Aug 6, 2017 01:41 PM
Turblown
Sep 30, 2015 05:58 PM
