Sponsored by: CARiD
smog pump
Old Aug 18, 2008 | 05:46 PM
CobraS89's Avatar
GXL
smog pump
hey guys i would like to remove my smog pump but i dont know where it is located on my 89 GXL could someone post up a diagram of the pulleys ive been trying to look for one online but can not seem to find one.
- Thanks
Old Aug 19, 2008 | 09:34 AM
InsomniacFC's Avatar
Will drive for parts
It's right next to the air box. You know your auxiliary ports won't open if you take it off, right?
Old Aug 19, 2008 | 10:41 PM
CobraS89's Avatar
GXL
can you explain the auxiliary ports? and i thought that was the water pump which is right next to the air box?
Old Aug 20, 2008 | 06:53 PM
On an S5 N/A (89-92) you need the air pump to open the auxiliary ports unless you rig something else up. Basically, these ports open at (give or take) 3,800 rpm and the VDI opens at 5,500 rpm to make more power. Taking the smog pump off will make it so they don't open anymore and you'll lose top end. You could rig them open, but it would be like "VTEC coming on at 1,200 rpms. "
There should be a rubber hose that's about an inch thick going from the air box to the smog pump. It's the pump that's the furthest left on your motor. I'd leave the smog pump on until you read more about the auxiliary ports. Just do a search for it in the 2nd gen tech section.
Old Aug 21, 2008 | 03:14 PM
CobraS89's Avatar
GXL
ahh ok thanks alot i might not remove it then do you know any other quick ways of making a few horses?
Old Aug 21, 2008 | 03:50 PM
The easiest would be bolt-on's like a cone filter, header, and catback. I don't know if smogging your car is an issue where you live, but you could either go with high flow cats, or delete them altogether. Doing weight reduction is a big plus in my book cause it's almost free depending on how far you go (i.e. dry ice to remove sound deadening). Go to the 2nd gen archive and do a search for "beefy N/A" or check out the N/A performance forum.
Old Aug 21, 2008 | 11:07 PM
ls1oo7's Avatar
Old Aug 21, 2008 | 11:59 PM
CobraS89's Avatar
GXL
is there a reason for the picture of this FC?
Old Aug 22, 2008 | 12:09 AM
Yeah, I don't know what a motorless parts car has to do with anything.
Old Aug 22, 2008 | 07:16 AM
CobraS89's Avatar
GXL
yeah hahah but it looks pretty clean body wise.
Old Aug 22, 2008 | 09:19 AM
I saw the other thread it was in. It was cut up into little pieces and sold for scrap.
Old Aug 22, 2008 | 10:16 AM
CobraS89's Avatar
GXL
ahh i see but it still doesnt explain why it was posted on here ha but i was looking at the 2nd gen n/a performance forums on here and created another thread on there to see other peoples opinions.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
BLK 93
11
Sep 9, 2015 10:56 AM
