Exhaust??
Old May 8, 2002 | 01:21 PM
86Rx7GXL's Avatar
Exhaust??
Is a 86 NA main cat the same as a 87 turbo2 cat?
Old May 8, 2002 | 08:32 PM
86Rx7GXL's Avatar
Anyone know? im not really sure id there the same diameter
Old May 9, 2002 | 10:11 AM
vaughnc's Avatar
knowledge junkie
NO. The Turbo II exhaust system will not work on an NA.
Besides, why bolt on the clogged OEM stuff anyway, go get a performance catalytic converter, downpipe, and nice cataback exhaust NOW!!!
Old May 9, 2002 | 10:30 AM
blu_gxl's Avatar
it will bolt up but you will lose all 5&6 port actuation unless you wire them open (which sux)or get rpm activated switch or use a t or y valve for the back preasure.
james
Old May 9, 2002 | 02:36 PM
86Rx7GXL's Avatar
nahhh im was wondering i have a turbo and i whated to take a NA main cat cut the cat out and weld a straght pipe in.
Old May 9, 2002 | 06:48 PM
86Rx7GXL's Avatar
are the flanges the same?
Old May 12, 2002 | 10:39 AM
86Rx7GXL's Avatar
Does anyone know if they are the same?
Old May 12, 2002 | 12:00 PM
Fingers's Avatar
as far as i know, no. They are not interchangeable. However, why would you want to do that? Shell out a few bucks for a Bonez Race Pipe. Very good quality peice, and it won't sound like ****.
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
FührerTüner
Sep 4, 2015 01:41 PM
