A/C clutch wont come on...
Old May 7, 2002 | 04:47 PM
DONNA's Avatar
replaced the old a/c because it had worn bearings and its clutch wouldnt come on either, can run a hot wire to the clutch wire to make it come on, but is there a relay or fuse that may be bad, also the device that raises the rpms when the a/c comes on doesnt work either, they both worked before but now they dont,,,thanks,,,
Old May 7, 2002 | 04:53 PM
Directfreak's Avatar
I am a Jeeper Now.
Those are symptoms of low freon in the system. Another symptom is the AC clutch engaging and disengaging right away. Check that before you look for other gremlins.
Old May 7, 2002 | 06:10 PM
DONNA's Avatar
did the freon check already, now to the gremlins,,,,
Old May 8, 2002 | 03:05 AM
nimrodTT's Avatar
all aboard!
Check the relay for the clutch, then check the a/c solenoid on the motor. Also check if the two trigger independently or are dependent on eachother. Then check the saftey switches to see if they are not working properly.
Old May 8, 2002 | 03:12 AM
Project84's Avatar
Open up! Search Warrant!
Can you change the A/C compressor without discharging the system? My Ford Explorer has same problem except the clutch won't engage even when you try a bypass on it. Compressor are pretty much the same on the inside, thats why I asked a Ford boinger question on here. I need the truck to tow my 7 too. There, now its a REX question
Old May 8, 2002 | 04:14 PM
85RX7GS's Avatar
I hope my A/C works when I get the engine running.
rotor_veux
Sep 19, 2015 07:13 PM
