Koyo or Fluidyne?
Old May 7, 2002 | 11:29 AM
HighRev's Avatar
Question Koyo or Fluidyne?
I live in a very hot climate and cooling is the next step in building up my 7. Which aluminum radiator do you guys prefer?
Is there a difference in the two other than the price?
How is fitment with the A'PEXi intercooler?
Old May 7, 2002 | 11:37 AM
Lost Time's Avatar
Chimera Driver
Search for "koyo vs. fluidyne" and enjoy the next hour reading.
Old May 7, 2002 | 03:29 PM
rxrotary2_7's Avatar
that is exactly what i was going to say. this has been beaten to death.
Old May 7, 2002 | 03:49 PM
1bad7's Avatar
haha, well im not one to tell you to go and search
go with the fluidyne, eventhough both radiators are very good. there are only 2 main differences between them. one is that the koyo is slightly thicker than the fluidyne (2.1" compared to 2"). and secondly the koyo has some fitment probs that require slight modification while the fluidyne drops right in. you weigh the pros and cons but i recommend the fluidyne. havent had a single prob with mine and temps drop very rapidly once the fans come one. very very rapidly
Old May 7, 2002 | 04:03 PM
Zoomspeed's Avatar
Even though the koyo has slight fitment problems, its ~$125 less then the fluidyne while being bigger (even though it is slightly).
Think about it. That $125 can get you some underdrive pulleys. Or you can get some Evans NPG to put in at the same time and have about $25 left for a tank of gas.
Old May 7, 2002 | 04:10 PM
vosko's Avatar
Just Call Me Terminator!
i thought pricing was around $375 for koyo and $425 for fluidyne now ? i got a fluidyne a WHILE ago when they first came out
Old May 7, 2002 | 04:15 PM
think thought he farted....but he realy **** his pants
j/k jon, thats what i thought also.
Old May 7, 2002 | 06:05 PM
Zoomspeed's Avatar
At the 7 store the fluidyne is $500 and the koyo is $375
Old May 7, 2002 | 06:56 PM
kundo's Avatar
My uncles shop is right by the Fluidyne warehouse and I have never gone to check if you can buy them wholesale. I'll go check sometime this week and let you guys know if you can buy them directly from there.
Old May 7, 2002 | 06:59 PM
mjw's Avatar
mjw
You can buy directly from Fluidyne, but unless you are a dealer it costs a lot more. I called them when I was in a pinch to find one ASAP and they are fairly close to me, I was quoted something like $600.. insane. Luckily SP Engineering in Industry had one in stock for me.. you can get them for less than $500 if you shop around.
Matt
93 SSM
Old May 7, 2002 | 07:01 PM
Import Convert's Avatar
Rotor Motor Sports has Fluidyne for $415 Koyo is $375
Old May 8, 2002 | 12:30 PM
You can get the koyo from radiator.com for $380 + $9 day or $15 overnight.
Old May 8, 2002 | 01:13 PM
You can also get the Koyo for $375 or the Fluidyne for $429 from http://www.absoluteradiator.com.
Old May 8, 2002 | 01:57 PM
jmo87's Avatar
im goin with a fluidyne from .
Old May 8, 2002 | 02:00 PM
jmo87's Avatar
freakin thing wont edit my post
Old May 8, 2002 | 02:07 PM
Brad's Avatar
dear baby jesus...
you probably mentioned one of the unmentionables
Old May 8, 2002 | 03:14 PM
twinturborx7pete's Avatar
Juris Doctor
I went with the Fluidyne, got it from for 400+ not bad at all, though i haven't noticed a change in my temp gauge, it likes to always sit at the half-way mark....
Any ideas? should it drop more? maybe not enough coolant? whats the deal? my car NEVER overheats though i can let it idle for 30min and no problems. needle won't move. so you guys tell me?! is there something wrong? or is everything ok?
Old May 8, 2002 | 03:17 PM
The stock gauge probably won't show any difference. It only shows drastic changes, and you'll still be in operating temp range, so it won't show anything but the standard "everything is fine" level.
Old May 8, 2002 | 06:07 PM
Juris Doctor
Ok that kinda puts an ease to my mind.
Old May 8, 2002 | 06:30 PM
sub-zero's Avatar
High Rev, I had lots of problems with my Apex front mount and a fluidyne rad. I had to get rid of the A/C condensor because the Apex brackets did not drop the condensor enough for the Fluidyne. But You can use the brackets and tap some new holes to make it fit.
Old May 8, 2002 | 06:42 PM
get an aftermarket gauge
MidnightOwl
Sep 25, 2015 10:24 PM
