help!
Old May 6, 2002 | 10:53 PM
2ndGen.rocket's Avatar
Ho's and Cadillac Doors
help!
i need help. I just put new gauge faces on and went to put my cluster back in the car, and none of it will work. None of the needles will go up, nothing. Any ideas on what is wrong?
Old May 6, 2002 | 11:01 PM
kleach18's Avatar
Just Looking Around
MAybe check to make sure that you pluged everything in correctly.
kleach
Old May 6, 2002 | 11:10 PM
Sniper_X's Avatar
that can be the only answer.
Aside from a blown fuse.
Old May 6, 2002 | 11:46 PM
do you think that since i put the faces over the old ones, the needles are sticking or something? I know everything was plugged in correctly, i tried it like 6 times
Old May 6, 2002 | 11:51 PM
Icemark's Avatar
Do things like the high beam indicator and turn signal indicators work?
if they do, then you probably just have a blown fuse.
If they don't you have a bad connection or ground screw on the back is loose.
Old May 6, 2002 | 11:55 PM
yeah that all worked, the backlights and everything worked too. Any idea on what fuse it would be?
Old May 7, 2002 | 12:23 AM
Icemark's Avatar
In the drivers kick panel the fuse listed as meter.
You can check to see if it is blown by checking the reverse lights. they won't work if that fuse is blown.
ok, all my fuses are good, and every other dash function works fine. The only thing that doesnt work is any of the gauges, voltmeter doesnt jump when i turn the key, rpms dont work when i start the car, absolutely nothing. Im clueless. Everything is properly ground in the back of the panel, i just have no f-ing clue. Well, at least my gauges look really good, too bad they dont work at all.
Old May 7, 2002 | 12:25 AM
Icemark's Avatar
And do the reverse lights work? (you'll need the key on to check)
Old May 7, 2002 | 12:29 AM
yeah they work too. I just went out again and checked that fuse too. im baffled
Old May 7, 2002 | 02:13 AM
ok, i may have found the problem, and if it is what i think it is then im up a **** creek. There is a little white piece of plastic at the base of the needle on each gauge, which makes the gauge move and retract and what not. Well I am missing 2 of them, on my fuel gauge and my temp gauge. If this is the problem, then any ideas on what to do about that?
Old May 7, 2002 | 02:35 AM
SonicRaT's Avatar
Super Raterhater
Well, you could try to remove the platic covering and see if you can even move your gauges by hand, if they require anything over the sligest force, chances are they are rubbing on the new faces.
Old May 7, 2002 | 10:13 AM
i did it, they move fine. the only thing is, when i move the tach, speedometer, oil pressure, and voltmeter, they all return to the position they sit in. the temp and fuel gauge dont
Old May 7, 2002 | 01:06 PM
any more suggestions?
Old May 7, 2002 | 01:38 PM
Aaron Cake's Avatar
Engine, Not Motor
If those little white plastic things are not there, then the temp and fuel guages won't work. I don't know about the other ones though...Were you rough on them? Even if you completely murdered them, they should at least TRY to move...Makes me think that there is an electrical problem....Perhaps you damaged your wiring harness? Or the plug on the guages? Have you tried resoldering?
Old May 7, 2002 | 02:00 PM
no, i took each needle out carefully by hand, and each plug came out easily in the back. Every ground screw is tightened, and there are no solder points that need to be redone. I only unplugged the thing one time, and it came out without having to use any force. I dont know how i would have damaged anything
Old May 7, 2002 | 03:02 PM
ok, it is definitely something with the gauges themselves. The speedometer works perfectly, and the Tach wants to work. the needle will go up a little bit, but it goes up really slow and only gets to like 2,000 rpm's even when im totally winding it out. The oil pressure gauge jumped up when i started the car, but it just stayed there and wouldnt go anywhere else. Still nothing from the voltmeter or temp and fuel gauges. So i dont know what the hell to do now. im gonna be installing aftermarket temp and oil pressure gauges because i think the mechanical ones are alot more accurate, but i have no clue what to do with the tach or my fuel and voltmeter gauges
Old May 7, 2002 | 03:06 PM
Icemark's Avatar
Sure sounds like a bad ground on the cluster now
