synthetic weight?
Old May 5, 2002 | 04:03 PM
racer rx's Avatar
synthetic weight?
I just changed to Mobil1 15w/50 this week. First of all I notice the turbo's are quick to spool up. Little less lag.
Good for my street-ported engine.
However with the thick weight behind it... the secondary turbo does not come in as hard. I always break the tires loose when the second turbo comes on line with the thinner oil.
I have seen many Japanese tuners using as thick as 20w70. WHY? And their temps are close to mine here in Canada. apox.-10 to about 30 degrees. "Weird"?
I Can't believe I held off synthetic for this long. But I think I might change to 10w40 Mobil 1.
What weights do you synthetic users use?
Old May 5, 2002 | 04:12 PM
racer rx's Avatar
Just wanted to add...
Now my Oil presure gauge actually works.... I get 3/4 high oil presure til the car is warm then at idle it settles to about 1/4 way up.
Instead of half way or nothing sometimes at idle.
Nice feeling--- when you never see that gauge drop to "0"
anymore... cheers...
Old May 5, 2002 | 07:55 PM
jmo87's Avatar
i used 20w50 royal purple when i ran synthetic
Old May 5, 2002 | 08:01 PM
Import Convert's Avatar
10W-30 Mobil 1
Old May 5, 2002 | 09:32 PM
racer rx's Avatar
Hi jmo87...
How come you don't use the Royal Purple anymore?
jc.
Old May 6, 2002 | 09:54 AM
rotary-tt's Avatar
2 babies - no back seats
10W30 Mobil One.
Old May 6, 2002 | 10:54 AM
juliof's Avatar
Has anyone used Exxon superflow synthetic I noticed its about $3 a quart vs $4+ for other brands.
Old May 6, 2002 | 03:09 PM
rx7xrx7's Avatar
I was told by a auto engineer when using synthetics to use the thinest weight acceptable. I use 10w-30 Amsoil. The synthetics protect and hold up better than petroleum heavy weight oils. People confuse oil pressure with oil flow. 10-30 gives better flow which requires less pressure. Has anyone read the motor oil bible?
MILOS7
May 9, 2016 06:39 AM
