Need MSD Wiring Help
Old May 5, 2002 | 10:52 AM
stevekh's Avatar
I have an MSD 6AL that I am putting in my car on the leading ignition. I need to know what configuration does the MSD require to work with the rotary - 4, 6, or 8 cylinder?? Thanks for your help.
Old May 5, 2002 | 12:57 PM
Racer 13B's Avatar
I not sure but I think it should be on 4 cyclinder mode.
Old May 6, 2002 | 01:22 AM
RETed's Avatar
Run it as a 4-cylinder - the rotary fires once every "crank" rotation, which is the same thing as a 4-cylinder.
-Ted
Old May 6, 2002 | 02:33 AM
soul assassin's Avatar
GTR eater
4 cyl
Old May 6, 2002 | 09:29 AM
black88conv's Avatar
Newbie
don't forget that on rx7 the body is a floating ground, bolt the ground off the msd to the chassis.if not it will not work it all.
Old May 6, 2002 | 10:09 PM
RETed's Avatar
Huh?
The RX-7 runs a negative chassis ground - not floating.
Connecting the MSD to the chassis is not recommended.&nbsp Even MSD writes in it instructions to put the thick black wire directly to the battery.
-Ted
Old May 7, 2002 | 07:19 AM
bingoboy's Avatar
Lava Surfer
heya, isnt the 6AL rev limited to 6000 rpm? or is the rpm count from the ignition different somehow for a rotary.
Old May 7, 2002 | 10:36 AM
RETed's Avatar
The rev limiter is "useless" if the CDI box is only installed on the leading coils.&nbsp The trailing coils will happily keep pushing the engine higher into the revs.&nbsp You need to install some kinda rev cut on all three channels (single leadings and both trailings) for a rev limited to be effective...
-Ted
Medevack1
Naturally Aspirated Performance Forum
13
Nov 10, 2017 04:53 PM
DocHoliday89
Oct 12, 2015 07:42 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
