So im stuck at work. TII cranks, no tach. no firing.
Old Jul 10, 2008 | 03:57 PM
Whizbang's Avatar
Respecognize!
did the coil just go bad? but even with that would one or the other get the engine started at least?
Old Jul 10, 2008 | 04:41 PM
w00t's Avatar
When the tack goes bad that usually means a bad trailing coil. I would source a replacement.
Old Jul 10, 2008 | 04:47 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
it should still start even with a bad trailing coil.. check your fuses. check for spark at your leading
Old Jul 10, 2008 | 04:52 PM
Whizbang's Avatar
Respecognize!
i just tried it again and now it started....wtf
this is the second time this week it has done this.
i think there is something with the wiring harness.
Old Jul 10, 2008 | 07:21 PM
Funkspectrum's Avatar
Check your grounds. Especially to the coil pack and the main grounds...
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
Monsterbox
Sep 11, 2015 03:29 PM
meetRoX7e
Sep 11, 2015 11:09 AM
