Please help!.. my clutch is sticking to the floor! whats wrong?!!
Old Jul 9, 2008 | 07:26 PM
zachCutthroat FcDrifter's Avatar
dorifuto soko!
Exclamation Please help!.. my clutch is sticking to the floor! whats wrong?!!
so i just got back from a drift comp. and i noticed my clutch felt wierd, so when i got home i saw the fluid was a bit low.. i added some and didn't think much about it. then i just got in my car again and the clutch pedal is sticking to the floor! it goes in and out of gear fine. but the cluch is sticking so i have to wedge my foot underneath it to pull it up!!
Old Jul 9, 2008 | 07:29 PM
Brody8877's Avatar
#FakeCarEnthusaist
ur clutch master cylinder is toast, change it.
Molotovman's Avatar
Ban Peak
ZOMG! DISASTER!
You need to sell your car or it will catch on FIRE!!!
If you did a quick search you'd find out it happens all the time. Somethign in your clutch hydraulic system failed. If I was you I'd replace both the clutch master and slave cylinders. One of them is bad.
Old Jul 9, 2008 | 07:38 PM
dorifuto soko!
Ah dang! thanks guys, so is that defanatly whats wrong? or could it be anything else also?
Old Jul 9, 2008 | 07:41 PM
need RX7's Avatar
Listen to King Diamond.
Try bleeding the clutch with the bleeder screw on the slave cylinder. My clutch pedal did the same thing when I first got the car, it worked fine after bleeding it.
Old Jul 9, 2008 | 07:45 PM
dorifuto soko!
haha yeah my fluid is so black! i'm going to try that, haha i love my fc but it sure takes up so much money! but i'm still keeping it!!!
Old Jul 9, 2008 | 08:20 PM
Texas_Ace's Avatar
Just bleed it, i bet that fixes it, also if your fluid is black, then bleed ALL of the old fluid out, do it until the new fuild is all that comes out. I just did this to mine and it works perfect.
Old Jul 9, 2008 | 08:59 PM
RX7_RaVeN's Avatar
Drivin without Pistons
If you bleed everything and your still having issues I would suggest rebuilding the master cylinder. I had the same problem you are having and after bleeding it still went to the floor. After opening up the master cylinder I looked at the spring that is inside of it and compared it to the new one and it was compressed too much. Once I reinstalled the new pieces everything worked great. GL
Old Jul 9, 2008 | 09:03 PM
dorifuto soko!
yeah thats what i was planning on doing, cause my car had sat for awhile before i got it so the little things like that are still all dirty.. haha i hope that fixes it cause i'm tired of spending so much money on making my car run.. i want to spend money on tunning it!!!
hhaa
Thanks alot you guys
whinin
Mar 30, 2019 07:53 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
The1Sun
Sep 7, 2015 10:21 PM
Frisky Arab
Sep 4, 2015 06:17 PM
