My 20B racecar thread
Old Jun 30, 2008 | 04:15 PM
thetech's Avatar
****** of disaster
Everyone else seems to have a thread so I'm starting my own!
As some of you may know, I have recently (sort of) completed a 20B turbo FC racecar. This car used to be an SCCA EP car which I turned into a super duper time attack/super unlimited car. Buildup thread is here: https://www.rx7club.com/20b-forum-95/my-20b-fc-roadrace-car-underway-663170/
I'm going to treat this as a sort of blog of my adventures as I usually learn alot during the process of building, rebuilding, and modifying this thing and would like to share.
So...
First up, brakes. I've been out testing with the car a couple of times and have mixed success with the brakes. First of all I am an idiot and had the brake master cylinders the wrong way around on my Tilton pedals. After I fixed that, braking was 'decent' I would say but not quite where I thought it would be. I was using the stock FC 4-piston calipers and rotor with Hawk blue pads. After the last session, here are the results:
So I decided to go on an upgrade path...a few people had replicated the old K2RD setup using the Wilwood 6-piston calipers including flynbryn on here who kindly gave me all the part numbers. But then I stumbled on a thread by Project7 on here where he had successfully fitted the Brembo calipers from the Evo to the FC spindles. The Evo rotor at 12.8" is bigger than the Wilwood setup, and not having to make a caliper bracket was a huge plus for me. So, following Project7's lead I picked up a set of Brembo calipers locally and set to it. Results are pretty glorious:
After consulting Tilton, they suggested using a 13/16" bore master cylinder for the front which arrives today. I'm hoping the increased pad area, rotor diameter and rotor thickness is going to be great for the car.
Next up, my RE-Amemiya wing had split in half the last time I used it. Not exactly what I was expecting from a $1500 wing, but still a problem I had to deal with nevertheless.
After a week of repairs, the wing was as good as new and I'm assured won't crack again. Thanks to Dave at ShineAutoProject for repairing it for a great price and doing an awesome job!
Next up I replaced the JIC coilovers. I really hated how these things felt on the track and was pretty pleased when I found out that RX-Heven was offloading lots of cool suspension pieces from his old FC project, including a set of double adjustable Koni coilovers built by Tri-Point. These are pretty cool pieces and have to be custom made due to the fact that there is no rear double adjustable shock made by Koni which fits the FC; they take a single adjustable sport rear and modify it to be double adjustable, pretty cool. I now have these on the car:
I'm going to be trying 650lb front and 400lb rear springs and will take it from there. This is a significant increase in spring rate as I previously ran 450lb front and 325lb rear. I felt the car was a little sloppy before and hopefully this will help.
I also upgraded the front control arms to the needle-bearing version AWR makes. They replace the bushings on the front control arms with needle bearings which eliminates binding - the difference in ease of motion is really incredible and I can't wait to feel how these are on the track! I also replaced the rear trailing arm outer pickup point with the bearing-ized version AWR sells - the stock bushing design used in conjunction with the AWR individual camber adjusters seems to be twisting and not moving quite as freely as it should, so this should help significantly.
And lastly for now, new brakes calls for new wheels! The Brembo's protrude from the hub about 2" so the old 16" steel wheels I had weren't even close to fitting. My favorite wheels ever are the CCW classics which I used to have on my old Z, so I picked up some 18x12 rear and 18x11 fronts with Hoosier 335/30 and 285/35 tires. Unfortunately they won't fit under my AWR fenders, so I have the Tri-Point replicas coming which will hopefully do the job. If not I'll have to look into getting RX-Heven's gigantic wide bodykit and trying that.
If all goes well I hope to be on track in the next 2-3 weeks. Just have to get the new fenders on, waiting for the new Hawk pads for the Brembo's, and the usual alignment/cornerbalancing. I can't wait!
Old Jul 1, 2008 | 03:29 PM
RX-Heven's Avatar
I'll blow it up real good
Looking good!
You know you are just going to end up running my flare kit too
btw, you should have been running the HT-10's up front to begin with.
Old Jul 1, 2008 | 03:37 PM
thetech's Avatar
****** of disaster
Actually prefer the feel of the blues to the HT10 on the RX7 calipers, but will be a totally new setup with the Brembo's and will have to start from scratch again!
Old Jul 2, 2008 | 06:32 PM
CJarrett's Avatar
FC Racer
Subscribing to this. Car sounds like it'll be a blast, thats the project I want to build really..
Old Jul 2, 2008 | 08:36 PM
SCCAITS's Avatar
SCCAEP
Car is looking good, not that it wasn't good already! Are those Dave's AWR control arms he was selling?
Old Jul 2, 2008 | 09:26 PM
white_charisma's Avatar
Jungle Boogie
car should be amazing, let us know how it goes
Old Jul 2, 2008 | 09:35 PM
thetech's Avatar
****** of disaster
Thanks! Yea, they are Dave's parts...the shocks, wheels, and control arms all came from him. At least I can rest easy knowing I'm helping him fund his new project
Old Jul 3, 2008 | 12:21 AM
RX-Heven's Avatar
Old Jul 6, 2008 | 10:56 AM
EProdRx7's Avatar
Funny thing is that when I first built the car for EP I bought a set of the TriPoint flares and then replaced them with the Mariah fronts and then the AWR fronts went it was sold. New wheels, much better!
Old Jul 6, 2008 | 01:47 PM
legokcen's Avatar
Car looks wonderful! I'm going to have to follow this for a while too. Good luck!
Old Jul 13, 2008 | 07:13 PM
thetech's Avatar
****** of disaster
Well ****. Got the Tri-Point fenders, but they're too small for the ride height I'm looking for. Guess I am going with RX-Heven's bodykit after all
Once I have the fenders/bodywork sorted out, I think I am all set. Just waiting for the brakepads to arrive and everything should be in order!
Old Jul 14, 2008 | 12:44 PM
sub9lulu's Avatar
i am assuming the big brakes wont fit under 16" rims since u sold them ?
Old Jul 14, 2008 | 12:49 PM
thetech's Avatar
****** of disaster
That's right, but mostly because the caliper mounts in such a way that it protrudes about 2" from the hub rather than it's overall diameter being a problem.
Old Jul 14, 2008 | 09:30 PM
thetech's Avatar
****** of disaster
Well I bit the bullet tonight...RX-Heven's giant bodykit will be here in a few weeks
Old Jul 14, 2008 | 09:50 PM
BASTARD's Avatar
Have you run it since you put the vented hood on? if so, how much cooler are your temps?
Old Jul 14, 2008 | 09:52 PM
thetech's Avatar
****** of disaster
Yes, hard to say as I never ran the 20B without it, only the previous 13B NA.
Old Jul 15, 2008 | 10:15 AM
Project7's Avatar
WORLD DOMINATION!
Awesome build and let me know how the brakes work out. I am still working on my setup, but I am really close. I will update my thread soon.
Old Jul 17, 2008 | 05:36 PM
gnx7's Avatar
Car looks great! Love the one off brake kit setup. I hope it does actually work without issues.
When you are ready to make 500hp flywheel from an n/a based LS1 on 91 octane let me know. I'm Dave's buddy... trying to convert him over to the dark side too
Old Jul 17, 2008 | 05:47 PM
thetech's Avatar
****** of disaster
What, so I can end up like this poor fellow? (sorry Joel)
http://www.v8rx7forum.com/v8-rx7-tec...tonwillow.html
Besides, 500 flywheel hp is for girls
Old Jul 18, 2008 | 10:02 AM
RX-Heven's Avatar
Mark, Mark, Mark.
Never ever gonna happen.
He could have just kept the rotary in it
Old Jul 30, 2008 | 09:10 PM
thetech's Avatar
****** of disaster
Look at this beauty!
Old Aug 5, 2008 | 12:17 AM
thetech's Avatar
****** of disaster
Behold the black, blue and white monstrosity! And my lord these things are unbelievably wide - in the pics, the right rear (which is 18x12 with 335 tire) has a 1" spacer and theres STILL probably about 2-3" spare. I could fit a 14" slick under here with no problem at all.
Thanks much to RX-Heven for yet another smooth 4 figure transaction
Old Aug 5, 2008 | 10:44 AM
RX-Heven's Avatar
Always glad to help
Old Aug 6, 2008 | 12:45 AM
thetech's Avatar
****** of disaster
Starting to take some kind of form...I'm giving up until I buy a pneumatic riveter
Old Aug 6, 2008 | 08:27 PM
BigAl...'s Avatar
Love your Fabricator!
Wow, I hadn't even noticed your thread. Your car is looking awsome, that body is really gonna look awsome when you paint it, are ya sticking with the same blue? what about the wheels (color)? Good Luck!
BigAl...
