Power FC base powerfc igntiming maps?
Old Jun 24, 2008 | 11:42 PM
dvd's Avatar
dvd
I just bought a fd with a 97 spec motor and power fc but it doesnt run right. It runs really rich. I looked at the ignition timing map for the trailing and leading they were set -25 all around. I'm wondering could this cause my primary not boost or stuttering when I get on the throttle? Should I just reinitialize all the data on the powerfc and just run the stock map? The car ran fine when i drove it 700 miles and I got about 24mpg or so.
Old Jun 25, 2008 | 08:07 PM
cewrx7r1's Avatar
Eye In The Sky
It could not even run with the timing you mentioned.
How did you view this all -25 timing?
Old Jun 26, 2008 | 01:36 AM
dvd's Avatar
dvd
I have no idea. the previous owner said it was tuned by some place but i forgot the name. Maybe its a security feature to not show the tune? I already resetted the pfc and it seems to run a little better. Still no boost but at least it feels a tad bit smoother.
Old Jul 1, 2008 | 01:43 AM
f150rx7's Avatar
hey it's john, I forgot to tell you about this, the reason why it displays the -25 all over the map is because the previous tuner locked it so no one will know their style of tuning (japanese tuners). It was done by R magic. I took it to another shop and they said they can actually unlock this so u can view the maps. I dont think you should change it though anyway since it's running the car safely with it's modifications. I guess you wont find out until you blow the motor and learn how sensitive they are. You boost problems is more likely from the control system not to ECU.
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
danielbradley2
11
Sep 28, 2015 10:44 PM
befarrer
Sep 22, 2015 09:33 AM
