Mounting bat cable under car?
Old Jun 22, 2008 | 04:37 PM
mykah89's Avatar
Im just in the process of running my battery cable under the car and was wondering what the best thing to secure the cable to the body is. Just before i go and do what im thinking hoping somebody has done this before and has a preferred method.
Old Jun 22, 2008 | 04:42 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Insulated clips for MC Light (go to homedepot or something of the like) would be my personal choice
Old Jun 22, 2008 | 05:31 PM
mykah89's Avatar
Then probably just some small self tapping screws into the under-body i suppose
Old Jun 22, 2008 | 07:03 PM
RX72NR's Avatar
paying to play
You could also route the cables thru the fire wall and the console to the bins. A rubber grommet installed where the wires pass thru the firewall will keep any wearing issues to a minimum.
Old Jun 22, 2008 | 07:50 PM
mykah89's Avatar
I have it in the hatch at the moment, hoping to just drill a hole+ grommet in the spare tire recess and loom it + run it along the bottom of the car... i was hoping that maybe there was a bette/different way than just screwing brackets into the bottom of the car.
Old Jun 23, 2008 | 05:40 PM
teenwolf1393's Avatar
BROKEN AGAIN
most people do what rx72nr is saying. you dont have to worry about th weathering effects on your cable. theres less of a chance for the cable to be damaged if its inside the car.\
plus if you route it thru the car you dont have to drill holes or go buy anything to hang the wire
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
smikels
Aug 18, 2015 01:26 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
