Sponsored by: CARiD
bridge port apex seal suggestions?
Old Jun 19, 2008 | 12:45 AM
nu-rx7junkie's Avatar
Ok I have searched for this anwser ,but have not came to a definate conclusion, and decided to post it. What type of apex seal can be used in a turbo 13b full bridgeport motor? I know that a half-bridge port can run any seal just flip the end peice. But I think I saw that 2 peice seal can be used opposed to 1 peice seals. So I want to run a full bridgeport but my atkins 2peice seals are almost brand new less 2k mile on them. Can I use those in a full bridgeport. If not I dont have the money for more seals and will run a half bridge. Thanks every one.
Mabey Dave Atkins knows?
Old May 21, 2009 | 03:12 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
I would like to find the answer also.
Old May 21, 2009 | 07:56 AM
rx72c's Avatar
Top Answer: 1
No problems running 2 piece seal on a full bridge as long as they are cut correctly.
Do your primary bridges alittle thinner and youll be fine.
If you want a big main port and bridge, one piece seal only.
But you can have your secondaries huge, primaries just small bridges. And youll be fine.
Old May 21, 2009 | 08:21 AM
jgrewe's Avatar
GET OFF MY LAWN
You mean the holes not the actual bridge you leave, right?
Devon300zx
15
Sep 16, 2015 06:57 AM
galvatron10000
Canadian Forum
Sep 8, 2015 08:50 PM
