oil gauge fix??
Old May 2, 2002 | 03:22 PM
sk8world's Avatar
Chasing numbers
oil gauge fix??
I know I have read this topic before but I can not seem to remember the solution. My oil presure guage is working right. It seems like it has a bad connection. Any help is great. MIke
Old May 3, 2002 | 10:57 AM
SanJoRX7's Avatar
uid 0
If you're referring to the pressure dropping to almost nothing at times, it's likely a problem with the sending unit, and not the gauge. I've talked to a number of ppl and they've told me that the sending unit on our cars just has a tendency to take a dump. It's a PITA to fix, and usually ends up broken again at some point.
I've heard you can remove the unit and clean it and that sometimes fixes the problem, but usually the fix is temporary. I dunno...anyone else have experience with this?
Old May 3, 2002 | 12:29 PM
sk8world's Avatar
Chasing numbers
I do not believe it is the gauge since somtimes it works. It seems more like a bag connection. When I first start the car its fine but after it warms up then it seems to just quit working and I know there is oil pressure in the motor.
Old May 3, 2002 | 12:36 PM
rynberg's Avatar
Remove the sender and clean it. The sender is a small plug about 6-8" below oil filter. It is on the driver's side of the oil filter mount. If that doesn't work, then the sender is bad, which is a common problem.
Old May 3, 2002 | 10:45 PM
kelrx7r1's Avatar
TNC
Talking
SANJORX7 AND RYNBERG TOOK THE WORDS OUT OF MY MOUTH
THEY SPEAK THE TRUTH
Old May 3, 2002 | 11:58 PM
A-Spec Tuning's Avatar
Registered User
degrease the sender and then try soldering the wire directly to the sender..wrap with Hi-temp electrical tape..works like a charm
good luck!
Old May 4, 2002 | 11:31 AM
sk8world's Avatar
Chasing numbers
thanks
Thanks for the help! Mike
Snoopy FD
Dec 8, 2015 01:45 PM
sYnth.
Aug 19, 2015 06:27 PM
tsmith94FD
Aug 16, 2015 05:41 PM
