rusted...
Old Jun 10, 2008 | 02:15 AM
sen2two's Avatar
Rx2 > FD
rusted...
so im sure if most of you were to pull the carpet up, we would find our 20+ year old cars should have some rust.
well, parts of my floors and other areas are rusted through. i can not find replacement floor pans. so....why not just cut it and and weld some new floors in?
anyone have this experience???
what about on the unibody frame? can i cut out the rusted pieces on the frame and weld in new pieces? i want to cut out, and replace with new metal all the rusted through areas...
any tips would be great.
Old Jun 10, 2008 | 10:29 AM
rotarymaniac's Avatar
Ive got an 84 gsl-se and the floors were rusted through, i patched the floors with 20g steel but now that i have a rust free parts car ill just swap both sides of the floor. good luck bc fixing rust is never ending with these cars.
Old Jun 10, 2008 | 03:28 PM
openshot's Avatar
Wankel Me This!!
i had to replace some floors and the back wheel wells dubble sided. its alot of work but well worth it in the end.
Old Jun 10, 2008 | 03:36 PM
az38rx7's Avatar
Newbie
hi yes everyone wants to know about rust? unless a car has been kept out of all weather for 25 years won't it have some rust? is this a post? I tried to answer my pm and was told I only have one post? --AZ
Old Jun 10, 2008 | 11:25 PM
sen2two's Avatar
Rx2 > FD
whats 20g convert to in inches and mm?
i buy my metal from online metals.
you guys have any pics during the process?
Old Jun 11, 2008 | 12:50 AM
.82 mm, i googled it. that doesn't sound like much but it did the trick to pass safety. I'll get pics when i rip the floor outa the parts car.
Old Jun 11, 2008 | 03:12 AM
sen2two's Avatar
Rx2 > FD
thanks...that is pretty thin, but that does alos mean light weight. lol
when you think you'll be swapping them floors out?
Old Jun 11, 2008 | 08:14 AM
82transam's Avatar
Never Follow
Much of the body is made out of 20 or 22ga metal to begin with so its thick enough for many of the patchs you might need to make. I did a lot of patching on both my cars using 22ga I bought at lowes.... For wheel weels and other areas that require some more strength I used 16ga. It's been years on the one car and everything is holding up nicely so far.
Old Jun 11, 2008 | 06:12 PM
TheRX7Project's Avatar
Daily Beaten
Rust free (**** full) cars FTW!
We patched the floors (actually, made compeltely new floors) in my old Bug using I believe 20ga steel welded to the "frame" (heater channels and center tunnel). I'm a big dude and it held me fine.
Old Jun 11, 2008 | 06:22 PM
Some time this month, im off work right now so in a few weeks maybe i'll be up for cutting and welding.
Old Jun 11, 2008 | 07:09 PM
Daily Beaten
Old Jun 12, 2008 | 07:18 PM
spin'nall4's Avatar
spin'nall4? only ina suby
you can beed roll the new sheet metal before putting it in to make it stronger. you can triple its resistance to flex just by putting a few channels in it. I saw it on trucks! on spike tv they even proved it by putting weight on the two panels to see how much either hold before bending.
TurboLumpy
NE RX-7 Forum
Jun 28, 2006 08:21 AM
Dukakis
Aug 15, 2004 02:37 PM
GoodfellaFD3S
May 21, 2002 03:45 PM
