Sponsored by: CARiD
s4 turbo rotors in s6 motor?
Old Jun 6, 2008 | 11:38 AM
b@@sted_fd's Avatar
I have been told that the s4 turbo rotors are better then the s6 rotors because they are stronger and less susseptable to being damaged/dented due to pinging/detonating. Any thoughts on this?
Old Jun 6, 2008 | 12:05 PM
SaabGuy's Avatar
Side seals are 2mm instead of 1mm
Old Jun 6, 2008 | 12:28 PM
b@@sted_fd's Avatar
I was told that the rotor walls are thicker. If you look at a cross section of a rotor, the walls I'm refering to are on the rotor faces above and below the pocket (or whatever they're called) on the rotor face. Apparently the s6 rotors are weaker there and can dent causing the apex seal to stick. Just seeing if anyone else has info supporting this.
Old Jun 6, 2008 | 01:09 PM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
Also have a half point lower compression ratio. I'm currently running a pair in my setup, though not fully tuned yet.
Old Jun 6, 2008 | 01:59 PM
84stock's Avatar
Ideal for running a higher level of boost. They are much stronger, but also heavier and you will need to match them with the right counterweight, flywheel etc. Great to use if you want to run boost. The heavier rotating mass slowed my throttle response a bit but launch and just simple take off is sweet. i love the daily driving aspect of my set up.
Old Jun 9, 2008 | 12:39 PM
b@@sted_fd's Avatar
cool. Thanks for the feedback guys ;-)
Old Jun 9, 2008 | 01:57 PM
joeylyrech's Avatar
87 SE WITH S5 T2 SWAP
they are use by some of the fastest drag racing cars,they are stronger plus super boost friendly
Old Jun 10, 2008 | 12:00 AM
initial D is REAL!'s Avatar
I heard the process they use to make s5 and s6 rotors was better though.
Please correct me if I am wrong
cristoDathird
28
May 30, 2019 08:47 PM
dkwasherexd
May 27, 2017 04:51 AM
