Mariah Single Turbo 3rotor Kit
Old May 1, 2002 | 11:24 AM
Kurgan's Avatar
Gaijin Racing
I was just looking around the web for some rear fender flares for my FC and I stumbled across this:
http://www.mariahmotorsports.com/wh...htm#3ROTORTURBO
There is no information on the site about the kit, but they do have a pictue of it. I can't tell what kind of turbo it is, but the kit looks farily complete from what I can tell, though no downpipe is shown.
I sent them an email inquiring on cost, availability and turbo specs, as well as the exact contents of the package and what chasis (FB, FC or FD) it was designed for. I'm assuming its made for an FC. I'll post on here when/if I get a response from them.
This doesn't look like something I'd be interested in, but a few of you may be, so I'll keep you informed. Mariah just seems to be kind of high priced, and I expect this will be as well. Hopefully not though...
I'm not one for bolt on kits, but this may not be a bad idea, if its a good deal... I'lll let ya'll know.
Old May 1, 2002 | 11:18 PM
RETed's Avatar
Damn, that URL doesn't work.
Is that the 10AE 3-rotor that still doesn't run right till this day?
-Ted
Old May 2, 2002 | 05:30 AM
mmaragos's Avatar
See if this works...
http://www.mariahmotorsports.com/ima...j/3rsingle.jpg
Old May 3, 2002 | 01:58 PM
j9fd3s's Avatar
Community Builder
the mariah 3 rotor car dynoed recently apparently they couldn't get it to boost. it seems like they never finished the car.
mike
Old May 3, 2002 | 09:09 PM
RX-Heven's Avatar
I'll blow it up real good
Didn't someone finally buy that thing that has posted on this forum?
Old May 4, 2002 | 03:13 PM
Evil Aviator's Avatar
Rotorhead
Is it just me, or does that look really small?
Yes
http://www.3rotor.us/page4.html
Old May 6, 2002 | 07:40 PM
Turbo III's Avatar
That guy posts on the nopistons forum by the name of 3 Rotor. I've mailed him a few times asking about his car but he seems to be one of those people that just said, "cool car" and bought it without maybe knowing all the stuff that went into it and the maintenance issues.
Old May 6, 2002 | 09:34 PM
RX-Heven's Avatar
Those Mariah kits are sooo ugly. Would be cool to have a 3 rotor fully accessorised though.
Old May 6, 2002 | 11:40 PM
Kurgan's Avatar
Gaijin Racing
Well, I just got an email late last week from Mariah. They said that each of their kits are custom made, and the turbo specs are pieced together and tailored to the certain customer's application. No mention of cost, or completeness of the kit... I sent them a message back asking how much a T76 kit would cost.... still waiting to hear.
Old May 7, 2002 | 02:05 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
Kurgan,
Did you ever find fender flares?
Old May 9, 2002 | 02:05 AM
InitialD FC's Avatar
Did anyone else notice the hks cast manifold with a pipe stuffed into the side?
Old May 9, 2002 | 08:18 AM
Rotorhead
Yes, it looks like a 2-rotor cast manifold with some weld els and an extra flange to feed the front rotor. The runners look like they are different lengths (not that I can talk, lol), and IMO that front runner is going to get stress cracks when the engine expands because they didn't use a 1-piece flange. Also, it doesn't look like there is enough hose and pipe for both a coolant feed/return and oil feed/return, so I hope they aren't going to unleash a dry bearing housing on the public. The DP isn't pre-bent, and I have no idea where that wastegate pipe is supposed to go, so it looks to me like this is a project in the works. I am thinking that this picture is only a mock-up concept for the proposed product.
Old May 9, 2002 | 01:29 PM
Kurgan's Avatar
Gaijin Racing
Originally posted by PaulC
Kurgan,
No, I never found any that weren't stupid wide. I just want 2, maybe 3" extra on each side... just so I can run some WIDE tires in the back.... Anyone know where to get something like that?
Old May 9, 2002 | 02:13 PM
RETed's Avatar
Wow, I didn't notice that until now!&nbsp Shows how much I pay attention!
$300 cast manifold, add another runner onto it - how much do they want for that???
-Ted
Old May 9, 2002 | 03:39 PM
13BAce's Avatar
On a long vacation
If you roll your fenders you should be able to squeeze a 295 in there.
Old May 11, 2002 | 10:21 AM
PaulC's Avatar
do you just roll the lip or roll and flare the fender out ?
Old May 11, 2002 | 10:58 AM
13BAce's Avatar
On a long vacation
You can just roll the lip, but flaring it out gives you quite a bit of extra clearance. I had to flare mine a little because I'm running 275/35/18's on an 18x9 with a +30 mm offset. If I had gone with a slightly higher offset I may not have needed to roll the fenders at all. My tires are about 1/4"-1/2" away from the trailing arm.
Old May 11, 2002 | 06:32 PM
Dyre's Avatar
Your Opinion is Wrong
What about the FEED/Run Racing Fender flares. I know they are hella expensive, but they dont look to be TOO extreme.
Old May 11, 2002 | 09:39 PM
RX-Heven's Avatar
Check out Tri-Points flare kit. About a 1/4 the price of thr Run racing $6000 rip-off. Excellant quality and they maintain the original body lines. Might flare more than you are looking for though. Hope the pic I attached works.
Old May 11, 2002 | 09:40 PM
RX-Heven's Avatar
It worked so here is another
Old May 20, 2002 | 12:12 PM
Dyre's Avatar
Anyone know how big the flares are on the Tri-Points Kit?
Old May 20, 2002 | 12:18 PM
PaulC's Avatar
I think this is turning in to a fender flare thread
But where did ya get those cause I wouldnt mind those ones
Old May 20, 2002 | 01:01 PM
13BAce's Avatar
On a long vacation
The flares they're talking abour are from http://www.tripointengineering.com .
Old May 20, 2002 | 01:02 PM
13BAce's Avatar
On a long vacation
Here's a picture from their site:
Old May 20, 2002 | 06:52 PM
HyperRex's Avatar
I posted some info on fender flares, but I realized I was majorly hijacking the thread. The message has been moved to a new topic entitled "fender flares and wide body kits"
sherff
Feb 24, 2019 12:09 PM
Turblown
Aug 14, 2015 04:48 PM
