Sway bar end link
Old May 30, 2008 | 08:59 PM
nocomply24's Avatar
Sway bar end link
Trying to replace a broken endlink. I cant get the sway bar in place, do i need to unbolt the whole sway bar for the install? i just removed the broken end and iam now trying to put the new one on and the sway bar is to far out.
Old May 31, 2008 | 04:04 PM
Josh18_2k's Avatar
put a jack under one of the hubs to move the sway bar.
Old Jun 1, 2008 | 10:20 AM
kenny senter's Avatar
is just one side in the air or are both sides in the air? If you put both sides (left and right) in the air it should take the load off the swaybar. If you've only got one side in the air (left OR right), you're gonna run into trouble trying to reinstall the bar.
Old Jun 5, 2008 | 11:59 AM
nocomply24's Avatar
both are in the air, but i think i will try to put a jack under teh hub and jack it up to release the load. Thanks guys.
Old Jun 5, 2008 | 01:06 PM
gracer7-rx7's Avatar
needs more track time
When I did it, I had to unbolt both end links from the control arm on the front sway bar in order to reinstall. You may also have to open up the metal 'sliders' that support the end link in the control arm. I did.
matty
Jan 18, 2020 10:39 AM
MazdaAspec
Sep 9, 2015 02:04 PM
need RX7
11
Aug 19, 2015 08:27 AM
