Non Turbo ECU Upgrade
Old May 1, 2002 | 10:10 AM
Nigel2468's Avatar
Cool Non Turbo ECU Upgrade
I have a non-turbo '86 GXL. Would an ECU upgrade improve performance? I did a forum search and all ECU upgrades talk about turbo boost pressures. Also, if I do the upgrade, should I accompany it with exhaust/ignition upgrade?
Thanks in advance.
Old May 1, 2002 | 10:12 AM
blu_gxl's Avatar
check mdrace.com they have a n/a chip that's good and there was another yesterday it was epi or something it was on the second gen page try a search. there are a couple hope it helps
james
Old May 1, 2002 | 10:35 AM
FPrep2ndGenRX7's Avatar
Are you talking replacement chip or a stand alone controller? I would guess there is power to be had with either one. How much? Depends on your mods and tuning ability.
I want to see a stock port N/A engine with a header and a Haltech controlling it. Just basic mods and a dyno sheet to show the results. Anyone??????
Old May 1, 2002 | 10:38 AM
Nigel2468's Avatar
Just looking for a good chip--do I need the capability of tuning/adjusting timing when I install it?
Old May 1, 2002 | 11:57 AM
I believe the chip takes into account the average mods the average enthusiast(sp?) will do and programs(timing advance, fuel map, red line limits) the chip like that. Your car may or maynot react as good as others with different mods but it should be an improvement. The differences may not be noticable but they are there none the less.
Old May 1, 2002 | 11:59 AM
Ryde _Or_Die's Avatar
Alright, well there is no real point in getting a chip without having intake/exhaust already. Do that before you go out and have your chip reprogramed. There is a JET chip at nopionline.
Old May 1, 2002 | 01:13 PM
vaughnc's Avatar
knowledge junkie
Just make sure the chip you get is made for the NA rx-7 and make sure it's for the Series IV NA engine (ie 86-88 years).
Make sure the chip is designed with the mods you have on your car (exhaust & intake upgrades most likely). Otherwise you'll see your fuel economy drop and gain no power.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
C. Ludwig
Jan 30, 2019 06:31 AM
MoTeC
Sep 10, 2015 07:58 PM
