Car barely accelerates
Old May 21, 2008 | 05:33 AM
BCam's Avatar
barely accelerate
I am having the same problems. Bought a 2002 FD with 40,000 kms, was running perfect and without warning could barely manage to keep an idle and went dead unless I kept reving the engine. Also, the car would barely accelerate. The engine sounds more lumpy now. Hope this isn't the beginning of the end of the engine. I noticed the throttle hits the oil filter but i didnt think this would effect anything really?? The engine and exhaust is done by amemiya, and have no reason to doubt it. Thoughts welcome, thanks..
Old May 21, 2008 | 06:02 AM
seanfd3s's Avatar
airplane apex seals
check your plugs and see what they look like, does its sound louder then before? boxer engineish.
for the main topic, can you have some one rev it up wile you go around check from where the noise is coming from?
Old May 21, 2008 | 06:11 AM
BCam's Avatar
yeah mate, it does sound lounder and boxerish. the plugs looked quite new from the outside so didn't change them with the oil, so I haven't taken them out yet. could the symtoms indicte bad fuel?
Old May 21, 2008 | 05:04 PM
dgeesaman's Avatar
1) Check your map sensor hose. Make sure it's still connected.
2) If the map line is good, get the compression checked. Your might have a blown motor.
Just because an exhaust is made by Re-Amemiya does not mean your car has the mods to support it. Cat-less exhausts are notorious for opening up the restriction so much that the stock boost control loses control. Too much boost = blown engine.
Dave
Old May 21, 2008 | 10:15 PM
lassen118's Avatar
check your cataliac converter the same thing happened to my friends car it was clogged and it barely accerated. once he replaced it it ran great. so check it out.
Old Aug 4, 2008 | 02:09 AM
BCam's Avatar
It was the seals, like every rotor owner will one day experience
sherff
Feb 24, 2019 12:09 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
alphawolff
Nov 17, 2015 05:57 PM
86glxNA
Aug 15, 2015 01:45 PM
