need advice on redline water wetter coolant.. any good
Old May 20, 2008 | 10:37 AM
Crybabii's Avatar
new ***** rx7
hi everybody.. I am thinking of buying a redline water wetter coolant is it any good in helping to keep my radiator working better and improve my cooling?? and how should i use it????
Old May 20, 2008 | 11:06 AM
dgeesaman's Avatar
Yes, it does work some. Just use a whole bottle with your coolant.
Dave
Old May 20, 2008 | 11:43 AM
Crybabii's Avatar
new ***** rx7
thanks dgeesman.. and should i use distilled water (the same i use for my battery) instead of normal water?? oh and how do I flush my old coolant?? thanks for the help mate..
Old May 20, 2008 | 12:26 PM
caredden's Avatar
Super Moderator
Veteran: Marine Corp
Use The Search Function!!
Crybabii,
While it is nice that some people will "spoon feed" newbies, you could save yourself some pain, and flames, if you would simply search...
I did a quick search for "coolant flush" and found multiple threads. I copied this one.
https://www.rx7club.com/showthread.p...radiator+flush
Almost every issue that may arise with an FD has been covered by someone. You just have to look for it. I understand that some issues are hard to locate, but at least make an attempt first before posting endless questions...
Charlie
Old May 20, 2008 | 12:32 PM
Rocking Rotary's Avatar
yeah water wetter seems to work well i even have it in my bike.
Old May 20, 2008 | 05:23 PM
dgeesaman's Avatar
Yes absolutely use distilled water and never ever use tap water.
I would drain out the radiator and pour in distilled and water wetter until it's full. Read up on how to "burp" the system as it's a pain to get all the air out.
Dave
Old May 20, 2008 | 05:28 PM
dhays's Avatar
If it has been a while since the coolant was changed, I'd even consider using a radiator flush/cleaner. Takes more distilled water, but it is pretty cheap.
As Dave said, search on burping. Based on a recommendation from someone here, I bought a special Lyle funnel for the purpose. It works great at getting all the air out of the system.
Old May 20, 2008 | 06:07 PM
4CN A1R's Avatar
sleeper
flush and burp how-to:
http://www.rx7.org/Robinette/flush.htm
cooling system discussions:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/big-fat-fd3s-cooling-thread-571088/
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/cooling-system-flush-info-441967/
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/fluidyne-radiator-ast-evans-questions-flushing-system-754045/
coolant burping tools:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/radiator-cap-funnel-eliminate-air-bubbles-342309/
Old May 20, 2008 | 06:24 PM
Would it be ok to leave the water wetter in the system while storing the car for the winter in a garage ?
Would my coolant freeze with this stuff in it ?
Old May 20, 2008 | 11:49 PM
Crybabii's Avatar
new ***** rx7
anyway thanks everybody.. sorry about the endless questions etc.. so if anybody else feels like charlie then I'm sorry.. anyway have to get back to flushing my system
Old May 21, 2008 | 12:26 PM
7_HEAVEN's Avatar
Arkansas Razorbacks FTW
Empty the entire system and use Evans NPG+ coolant. It is completely waterless and never needs replacing. It's been an outstanding product, I have been running it for over 5 years now with no issues whatsoever.
Water Wetter is an amateur solution to what the cooling needs are in an FD.
Old May 21, 2008 | 04:52 PM
dgeesaman's Avatar
Going back to the water wetter option, if you want to get the most out of it, you should be running mostly / all distilled water. Running it in 50/50 coolant isn't getting the best cooling.
But if you're in Toronto, 100% water is not safe for winter. I run mostly distilled with water wetter in summer and drain/replace back to 50/50 for winter. Given how important fresh coolant is in these cars, I think it's time well spent.
Dave
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
FD7KiD
Aug 17, 2015 11:50 PM
