Top feed primaries, rails and seals
Old May 18, 2008 | 08:37 PM
slo's Avatar
slo
registered user
Hi, I searched a found a few threads about top feed primary injectors sealing by cutting the top of the diffuser and using that as a seal, but in my own playing with it, it looks like just using 2 of the flat lower O rings would put the injectors in about the right place, and should seal just fine.
Anyone done this?
As far as fuel rails go are there any alternatives to the KG parts rail or is that the only choice?
Thanks..
Old May 18, 2008 | 08:44 PM
Mahjik's Avatar
Mr. Links
Arrow
Another choice:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/new-fuel-system-fd3s-%2A%2Acj-motorsports%2A%2A-603442/
Old May 18, 2008 | 11:10 PM
gracer7-rx7's Avatar
needs more track time
you and speed of light should talk sometime. he has a bunch of r&d time in the primary injectors and fuel rail.
Old May 19, 2008 | 03:34 PM
RotaryBred's Avatar
Lost You in the Rear View
i have the CJ fuel setup.. very good quality and i recommend it. also comes with the adapters to use the top feeds without cutting diffusers and stacking O-rings. it is also the only fuel system that i know of that uses rails that do not look like the KG rails. the KG rails are just made from generic extruded aluminum stock that everyone else uses so the CJ rails give your engine a very unique and "modern" look
Snoopy FD
Dec 8, 2015 01:45 PM
