Turbo problem or clutch slipping ?
Old May 16, 2008 | 01:52 PM
I have noticed sometimes that when i shift fast from 2nd to third,
my RPM's dont go anywhere and they are usually stuck in the 4k- 4500 range, but my boost gauge is showing me 10psi of boost.
now is this a clutch slippage problem or is my boost off ?
Old May 16, 2008 | 01:59 PM
Mahjik's Avatar
Mr. Links
Generally when the clutch is slipping, the rpms climb but the car doesn't accelerate. That shows that the engine is spinning but the power isn't tranferring to the wheels.
It typically starts in the upper gears (4 & 5) as the load is much greater than the lower gears. You'll also get that burning clutch smell when it's happening.
Old May 16, 2008 | 02:27 PM
SEEMs to me it could be a boost problem
Old May 16, 2008 | 02:40 PM
gainer_reniag's Avatar
so it seems...
Old May 16, 2008 | 02:49 PM
well then,
what could possibly cause my boost guage to respond, and no power be put to the wheels during this 2-3 seconds?
When I am below 4800 RPMs I do hear a noise that does seem like air or something is traveling somewhere it should not be... Like as if something is sticking open.
I had this problem last summer near the end so i didnt bother fixing it or looking at it. I was going to do it this summer as soon as i got my car out.. but the problem had disapreared on me for the past month.. now it is back...
It is very intimitent, but when it does show up it will stay now for a while =(
i guess i need to take things apart...
Any idea of where i should start looking ?
Old May 17, 2008 | 03:20 AM
durranibazli's Avatar
wb123...i would search for threads about the y-pipe...might help with your problem
Old May 17, 2008 | 12:13 PM
How can i visually inspect the Y Pipe to tell if it works correctly or not
Old May 17, 2008 | 10:30 PM
Mahjik's Avatar
Mr. Links
There's not much you can check visually. The stock Y-pipe has a coupler which is a weak spot that can fail. Most likely you won't be able to tell if there is an issue with it unless you remove it.
Old May 18, 2008 | 12:12 AM
Ok
well when I am boosting under 4500rpm i can hear a whooshing sound and the car does not creat more then 5 psi at best until i get it up into parallell mode 4500 + or so...
Could this be caused by a faulty y pipe?
also... Could there be something wrong inside the Y pipe? Im not sure what it looks like in there or what the main activity the air pipe does, but from looking at the Efini one, there is a plate or something inside the efini y pipe if i can recall correctly...
Old May 18, 2008 | 12:19 AM
Mahjik's Avatar
Mr. Links
Do you have full boost after 4500 rpms?
Old May 18, 2008 | 12:27 AM
Yes i do get about 10-12psi
If i can recall, everything was working fine up until a few days when i took the car out when it was a bit coolish, i boosted to about 15psi and ever since i did that I have been having the problem.
Same thin happend last summer.. was working fine.. took it out for a late night cruise boosted a few times hit 15psi once or twice... next day barely any boost out of the primary...
Old May 18, 2008 | 12:30 AM
Mahjik's Avatar
Mr. Links
If you get full boost after 4500 rpms, then it's not a boost leak. It's a problem with the control system somewhere. I would start checking these three parts to the turbo system:
Pre-Control
Charge Control
Turbo Control
http://www.autosportracetech.com/RX-...leshooting.htm
Old May 18, 2008 | 12:32 AM
Ok thanks alot for the help
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
rx7jocke
Aug 15, 2015 03:36 PM
