NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
Rebuilding Oil Cooler Lines Near N. NJ?
Old May 13, 2008 | 10:24 AM
toplessFC3Sman's Avatar
I'm wondering if anyone's found a hydraulic shop (or anyplace) that would replace the flexible portion of the oil cooler lines near northern NJ. I have a spare set of lines that I'd like to get repaired so I can throw them on the car as I put it all back together. Thanks a lot!
Old May 13, 2008 | 11:50 AM
su_maverick's Avatar
Back in the 7 life again
Why not just go with aftermarket lines? You arent talking about alot of PSI so you should be fine. I know that there are adapters from the cooler fitting to AN.
Old May 14, 2008 | 03:11 PM
rebuilding the stock lines should be much cheaper and can get finished more quickly than aftermarket lines could be made/shipped. I imagine I could McMaster it all out too, but thats a lot to do, and id still need some flexible bits in there, plus it may be difficult to determine what all was needed beforehand to put it all into one order.
Old May 14, 2008 | 03:25 PM
If the T2 oil cooler is anything like the FD one you would need -8AN line with 2 x block adapters and 2 x cooler adapters
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
