Sponsored by: CARiD
HELP! Apex seals or?
Old May 9, 2008 | 11:37 AM
TheRX7Project's Avatar
Daily Beaten
Exclamation HELP! Apex seals or?
OK I got the 12a home and decided to crank it over and check the apex seals by listening for the "pss" sounds with the leading plug out.
My front rotor is fine but the back rotor has the typical "pss......pss.....pss" of a blown apex seal.
This car sat for a while, is it possible it could be another problem? Is there anything I should try before yanking the motor?
Old May 9, 2008 | 11:41 AM
Rocking Rotary's Avatar
Do a real compression check and find out. That or look pull the exhaust manifold off and take a look to see if they are all still there.
Old May 9, 2008 | 11:49 AM
Daily Beaten
I'll try pulling the manifold later today. I'm also going to try putting some oil into the peanut and see if it frees anything up.
Old May 9, 2008 | 12:36 PM
Use ATF. It cleans will it makes compression.
Old May 9, 2008 | 12:45 PM
FelixIsGod29X's Avatar
Manual Rack
Ive heard to use MMO and not ATF. Just my .02
Old May 9, 2008 | 03:19 PM
Daily Beaten
Mmo?
Old May 9, 2008 | 03:34 PM
coxxoc's Avatar
Shooting for 500
Use a compression tester. If you get two low bounces you have a blown apex seal. If they are all low, you have more than one blown. Taking the manifold off takes 3x as long.
Josh
Old May 9, 2008 | 09:32 PM
Daily Beaten
OK I did a compression test, and the front rotor is extremely weak and the rear one has a blown seal. Motor swap/rebuild time.
What is the MINIMUM required to replace apex seals? I'm really stuck by time constraints here, I'm losing my garage space as of 5/20, so it needs to be running or go into storage.
Old May 9, 2008 | 10:56 PM
MazdaMike02's Avatar
Mazda Tech
All apex seals..don't half *** apex seals.
Old May 10, 2008 | 08:13 AM
Daily Beaten
I'm buying another motor. I wouldn't just replace some apex seals that would be like re-ringing only a few pistons. I meant as far as gaskets and whatnot is concerned. But this motor is getting yanked and rebuilt... ported and boosted.... YUM.
Old May 25, 2008 | 11:53 AM
yetterben's Avatar
7less for now!
dude i am sorry about the car and ebay thing. *sigh*
Snook
Oct 8, 2015 10:09 PM
