I just replaced my fuel filter and o2 sensor and now.....
Old Apr 29, 2002 | 02:03 PM
rx7power's Avatar
now my car loses power and just can't seem to pass 7000 rpm. It accelerates fine up until 7000rpm and then it just bogg. I floored it but it just doesn't seem to want to go past that rpm. oh yeah, its a 90 GTU.
Thanx
Old Apr 29, 2002 | 02:20 PM
biorotary's Avatar
could be your timing...sounds like it's running lean at high rpms...
Old Apr 29, 2002 | 02:27 PM
soulbrotha's Avatar
yea, i just replaced my fuel filter and like about 100 miles or so after, like i loose all power if i hit the accelerator hard and i hear a whisping sound outside like the engine is spraying air everywhere, if you figure it out, email me :soulbrothanumone@aol.com
Old Apr 29, 2002 | 04:18 PM
RX-Revvin's Avatar
You want to play craps like soul brotha numba one? Sorry
Are these OEM fuel filters? I've seen a few posts that say aftermarket fuel filters don't flow as well as Mazda ones. Maybe doing a search could help you out more. Good luck.
Old Apr 29, 2002 | 05:13 PM
rx7power's Avatar
rx-revin
I got the fuel filter from Victoria British, I thought it was going to be OEM mazda but it wasn't, should i get the mazda one, and my o2 sensor is a bosch brand.
Old Apr 29, 2002 | 10:42 PM
ka8legend's Avatar
If the filter was installed where the inlet is towards engine rather than the gas tank, would the motor still run or does it flow in either direction, but less efficient if not installed correctly.
Old Apr 29, 2002 | 10:53 PM
ka8legend's Avatar
disregard
eom
Old Apr 29, 2002 | 11:06 PM
tmak26b's Avatar
USE FACTORY OEM FILTERS. It's been PROVEN that some aftermarket fuel filter cause bad fuel pressure
Old Apr 30, 2002 | 12:24 AM
RX-Revvin's Avatar
Check out this thread:
https://www.rx7club.com/forum/showth...threadid=65799
Old Apr 30, 2002 | 12:52 AM
rx-7fc's Avatar
is a bosch filter any good becasue that is the one that i have
Old Apr 30, 2002 | 10:43 PM
rx-7fc's Avatar
bump
Queppa
Nov 18, 2024 03:47 AM
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
sYnth.
Aug 19, 2015 06:27 PM
