Power FC PFC base map ceiling
Old Apr 29, 2002 | 12:43 PM
mjw's Avatar
mjw
Well I just spent the last two days installing my Blitz front mount, got the power steering back online and bleed the cooling system.. but now I am scared to drive it with full boost. I know the base map is supposedly good up to intake/DP/exhaust mods, if I keep the boost down to stock levels can I make it a week or two until I can get XS to reprogram it? Luckily I still have the stock main cat in place to keep the boost down.. I am dropping in the Denso fuel pump tonight to make me feel a little safer. Mods below:
Apexi intake
Blitz cat back
3" SS downpipe
home depot boost control (set @ 9psi right now)
Power FC
Fluidyne
Blitz fmic
Matt
93 SSM
Old Apr 29, 2002 | 01:23 PM
mjw's Avatar
mjw
Ok, so I did some more searches.. it seems like I should be fine. I may switch over to the base mod map I think.
Matt
93 SSM
Old Apr 29, 2002 | 01:40 PM
Rotary Master
What did you come up with because, I will there shortly.
I have an intake, dp, rb dual tip and soon to have an M2 SMIC and I can't get to KD until late July.
Old Apr 29, 2002 | 03:16 PM
mjw's Avatar
mjw
Well when I get home from work tonight I am going to program in the base mod map and see how it does, just keep an eye on the gauges.. I think the base mod map will be plenty of fuel. I may work in the 'safe map' another user on this forum came up with to tame down the aggressive timing up top the PFC has.. do a search for safe map and you can download the excel sheet data, he also explains his logic for coming up with the ignition timing/split he used.
Matt
93 SSM
Old Apr 30, 2002 | 03:08 PM
Wade's Avatar
Be careful with the base map, it was too lean for my car with the typical bolt ons... verified with a wideband lambda. Same for Chuck Westbrook. I'd add about 5% with the PIM from 10psi+ just to give a little safety margin.
Wade
24seven_dada
20
Nov 10, 2018 12:03 PM
danielbradley2
11
Sep 28, 2015 10:44 PM
befarrer
Sep 22, 2015 09:33 AM
Mps_hell
Sep 19, 2015 10:02 PM
