Part number mystery
Old May 8, 2008 | 09:53 AM
Banzai-Racing's Avatar
Rotary Specialists
Part number mystery
Ray at Malloy and I have spent the last week trying to find the part number for the heat shield that bolts to the passenger side motor mount. Neither of us has been able to locate it in the parts sheets. If anyone knows the part number your help would be appreciated.
Thanks
Chris
Old May 8, 2008 | 10:22 AM
afterburn27's Avatar
Lets Go Hokies!
This is a semi-guess... but part # N3A1-13-3801 looks like the heat shield you want (1E-4 in the '93 parts cache). I'm just going by the pic and how I remember the heat shield. I can check it out when I get home for sure.
BTW, I have an extra one if you need just one.
Old May 8, 2008 | 03:54 PM
dgeesaman's Avatar
Check sheet number 1-F4, d-code 13-3801 #2. I think that's the one. PN N3A2-13-C80C
Dave
Old May 8, 2008 | 06:32 PM
Lets Go Hokies!
Dave
I think we are looking at the same piece. It is listed as 13-3801 # 1 in my sheet. PN N3A2-13-C80C
Old May 8, 2008 | 07:06 PM
dgeesaman's Avatar
On my 94 list, 13-3801 #1 is the lower turbo heat shield that covers the wg/pc actuator rods.
13-3801 #2 is the one that sits separate and looks like the mount heat shield.
Old May 8, 2008 | 07:11 PM
ObliqueFD's Avatar
Old May 8, 2008 | 08:31 PM
dgeesaman's Avatar
Hmm, that's odd they switched up the d-code and still use the same part number.
Anyway, I think the thread is nearing a conclusion.
Old May 8, 2008 | 10:12 PM
ObliqueFD's Avatar
Make sure you are looking at the right No. 1 and you aren't getting N3A1 and N3A2 mixed up. I think you might have.
Old May 9, 2008 | 05:47 AM
dgeesaman's Avatar
In the 94 parts fiche it looks a little different.
Old May 9, 2008 | 05:54 AM
Rotary Specialists
I looked at that same parts detail a few times, the strange thing is that where they placed this shield is nowhere near it's true location. This is also a bad drawing of it considering it is not rectangular and does not have the tab off the top. One of the confusion factors is that the motor mount detail does not show any shields at all.
Old May 9, 2008 | 06:33 AM
dgeesaman's Avatar
I suspect the turbocharger guys are the ones who determined a heat shield was necessary.
While it's not easy to find, it is fairly close within the engine bay.
Dave
diabolical1
30
Jan 30, 2016 05:50 AM
josef 91 vert
23
Sep 3, 2015 11:20 AM
