Rx7 1995 Automatic Idle Problem
Old May 8, 2008 | 02:32 AM
GAZA1725's Avatar
Hi all i have done a search and looked through quite a few posts but can't find the problem i have which is on a automatic.
First off the car runs and drives great no problems whatsoever it just when in idle it is up and down but as soon as you put your foot on the brake and either put the car in Drive or Reverse the idle sits fine again.
Also instead of making another thread another little problem i have is my rev counter keeps sticking again done a search and can't find anything any help with these problems would be very much apree
Thanks
Gaz
Old May 8, 2008 | 12:38 PM
ObliqueFD's Avatar
Check your Throttle Position Sensor settings and clean your throttle plates. It is also possible that you have a small vacuum leak which would cause a higher idle. The ECU then tries to correct it by lowering the idle, causing the fluctuation. It is most likely your TPS.
https://www.rx7club.com/showthread.p...&highlight=tps
Old May 8, 2008 | 01:57 PM
GAZA1725's Avatar
Thanks buddy i will have a read up , any idead what might be causing the rev counter to stick ?.
Will it just be a faulty clock
Kyo
Apr 13, 2019 09:24 AM
alphawolff
Nov 17, 2015 05:57 PM
ncds_fc
Aug 15, 2015 10:06 AM
rkhanso
Aug 13, 2015 11:40 AM
