What kind of Pre mix oil do you use????
Old Apr 28, 2002 | 01:21 PM
JAMMNN's Avatar
I am looking for some brands of pre mix oil. How about 2 stroke?
Old Apr 28, 2002 | 01:28 PM
SpeedracerRX7's Avatar
I have always used Marvel's Mystery Oil. I add around 4 Oz. to a tank. I have heard that Pettit offers a pre-mix but you have to order that from them, where as you can get Marvel's almost anywhere.
Old Apr 28, 2002 | 01:35 PM
evel333's Avatar
I use Valvoline Marine 2-Stroke or, if I can find it, Castrol Synthetic 2-Stroke. I add 4 oz. to a tank before refueling.
Old Apr 28, 2002 | 02:07 PM
jmo87's Avatar
is that 4oz everytime you run it almost empty? or does it matter? i just figured over time if you never ran your tank closer to empty before adding premix you would end up with more oil trhan gas at some point. does that make sense?
Old Apr 28, 2002 | 02:12 PM
1bad7's Avatar
pettits protek-r, best stuff out there
Old Apr 28, 2002 | 02:22 PM
Pumped's Avatar
I use castrol 2 stroke, I only premix when I pump up a full tank. But when the gas is crazy expensive, i usually go 20 liters no premix then i'll prolly dump in 1~2 ounce the next time I pump quarter tank...
Old Apr 28, 2002 | 02:24 PM
purepsi's Avatar
protek R here, 4oz per tank full
Old Apr 28, 2002 | 02:45 PM
Anytime I get below a 1/4 of a tank I fill up with 94 octane and 4 oz. of Marvel's. Before I had my engine rebuilt it smoked a bit on startup and using that got rid of it. I have heard it is good preventative maintenance and it seems to help on cold startups as well.
Old Apr 28, 2002 | 03:17 PM
artguy's Avatar
WTB** Very Low Miles 94-95
wesson
Old Apr 28, 2002 | 03:27 PM
Street King's Avatar
*** Bless Texas!
I really want to start pre-mixing but I cant bring myself to dump oil in my gas tank(weird uh). Wont it slow down the fuel pump and also clog the fuel filter? If it doesnt clog the fuel filter wouldnt it overall slow down the process of fuel going from tank to engine?
Old Apr 28, 2002 | 04:24 PM
i use synthetic polaris jetski 2cycle oil, supposely same thing pettit sells.
4oz every full tank.
Old Apr 28, 2002 | 04:37 PM
ZoomZoom's Avatar
SEMI-PRO
I heard that same thing.
Old Apr 28, 2002 | 05:12 PM
skunks's Avatar
I'm a CF and poop smith
i just started using quicksilver premium 2 cycle outboard oil, (found it at Kmart one night). it seems to have made my engine have a little more torque in the lower rpms and my engine seems to beable find its idle and stop hunting a little sooner then usual.
good luck
Old Apr 28, 2002 | 05:21 PM
RecKleSs's Avatar
Adrenaline
Pettit Racing's pre-mix.
www.pettitracing.com
Old Apr 28, 2002 | 10:54 PM
JAMMNN's Avatar
What about Yamaha oil injection mix for snowmobiles?
It is a high quality oil but is for oil injection motors, I would think it will blend well with gas? Any ideas??
Old Apr 29, 2002 | 01:48 AM
Enthu's Avatar
Still has an RX7.
Hey guys, there is some special oil metering pump available for our cars that'll let you use 2 stroke oil and not have to premix. it adds anothertank that connects to the new OMP and brings in the 2 stroke instead of the 4 stroke oil. so you don't have to worry about any fuel lines or pump issues, or pre-mix amounts for that matter.
Old Apr 29, 2002 | 01:55 AM
RotaryKnight's Avatar
for everyday driving 4oz of Marvel's also...stuff is cheap as hell too.
Old Apr 29, 2002 | 03:08 AM
dclin's Avatar
Perpetual Project
Premix oils are designed to be added to gas, and therefore blend with and travel thru the fuel system like gas. You're only adding 4 to 8oz premix per fillup (16+ gallons) so its perfectly fine.
Old Apr 29, 2002 | 02:13 PM
ok i am lost, does the car run any better with oil in the gas. I am use to doing this on my dirtbike but this is alittle crazy. I never thought that you could do this on the 7. who wants to enlighten someone like me who knows nothing about this! thanks
Old Apr 29, 2002 | 02:19 PM
1bad7's Avatar
adding a product like protek-r to your gas reduces overall wear and tear on your rotors and housing prolonging the life of your motor. this is especially beneficial on cold start ups where lubrication of the internal parts is at its minimum. this way as soon as gas reaches the combustion chamber, bam, uve got lube.
i highly recommend that you use a specific product such as protek-r due to the fact that 2-stroke oil and gas do not mix well. all the rotary specific gas additives dissolve very well in gasoline and donot "slow-down" or damage anything.
Old Apr 30, 2002 | 08:39 AM
so i can just buy this stuff and add the proper amount every now and then and it will work fine?
Old Apr 30, 2002 | 09:49 AM
xchaos's Avatar
Anyone have any experiences with the above mentioned Oil Metering Pumps?? I kinda like the idea, but am cautious!
Old Apr 30, 2002 | 10:13 AM
1bad7's Avatar
thats the idea. you add about 4 oz to every full gas tank or so. more if your gonna be pushing the car hard.
now just so u understand, if your motor is already bad then this stuff wont do much. its only used to preserve a good running motor and keep it healthy... not make it healthy
The1Sun
Mar 18, 2018 11:08 PM
sypath
Aug 16, 2015 12:06 AM
Clacor
Aug 14, 2015 09:17 AM
