Sponsored by: CARiD
no spark no fuel...??? please help!
Old Apr 26, 2008 | 05:51 PM
RotaryBred's Avatar
Lost You in the Rear View
i've posted this a number of times with no answers so i'll post it again since i've now updated the info... i had a short in my wiring harness on my 93 FD so in turn i pulled it out and fixed it up. the short was in wiring that i had meant to remove (emmisions controls.. etc) but never did cause i am a dumbass. i re-installed the harness and now i have no spark and no fuel. i tested for voltage pulses from all of the connections on the ECU and at the harness connectors with no luck. i also checked for continuity from the connectors to the ECU on the wires for the injectors and the igniter, as well as shorts between the wires. everything checked out ok. i then assumed it was my PFC that was burned out from the original short in the harness, so i plugged my stock ECU back in to verify this (assuming that my engine would at least try to start) and i still got nothing. so my question is... what is left to check? my only thought is my crank angle sensors, but how do i check those without an osilliscope? anyone else have any thoughts on this issue???
Old Apr 26, 2008 | 06:57 PM
jay85gs's Avatar
4x110 SUCKS!
You might want to check all your fuses and definitely your fusible links, you may have popped one.
Old Apr 26, 2008 | 07:03 PM
RotaryBred's Avatar
already did
Old Apr 26, 2008 | 07:17 PM
jay85gs's Avatar
4x110 SUCKS!
Find someone with a scanner, this might point you in the right direction or at least narrow the problem(s) down.
Old Apr 27, 2008 | 01:43 AM
RotaryBred's Avatar
i dont have the stock ecu i'm using a power FC... i put my stock ecu in and flashed my codes but got nothing useful... i think my crank angle sensor is cooked
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
23Racer
Race Car Tech
Sep 21, 2015 10:48 AM
