another dumb question from yours truly
Old Apr 21, 2008 | 02:46 AM
Red_Rabbit86's Avatar
new to the rotary world
will the t2 brakes bolt right up to the chassie/ hubs
Old Apr 21, 2008 | 07:29 AM
VacavilleFC's Avatar
no you need the hubs and new soft lines
Old Apr 21, 2008 | 08:12 AM
Go48's Avatar
Wait a minute! If you have an S5, you do not need different hubs at either end. For the front calipers, you need the hard lines. Existing soft lines will work, although it might be a good idea to change out all soft lines for SS lines. The TII rear calipers require a different rotor. The proportioning valve is different on the TII, but you don't have to replace that for the system to work.
And do yourself a favor. Rebuild the calipers before installing them.
Old Apr 21, 2008 | 12:52 PM
Icemark's Avatar
And remember very very few models didn't come with the Sport/Turbo heavy duty 4 piston brakes anyway.
If you have a Sport, GXL, Turbo, Convertible, 88 GTU, 89-90 GTUs, or 91 Coupe with A and B packages, you already have the heavy duty brakes.
Only if you have a Base, Luxury coupe, SE, 89-90 GTU, or 91 coupe without A and B packages; then you will have the single piston front brakes and solid rear rotors.
Old Apr 21, 2008 | 05:32 PM
thanks. i was just looking at going to napa and get a reman 4pis brake kit. i just didnt konw what else iwould have needed. i was looking at getting a whole new set up, ie new cali, rotor, springs the whole deal.
Old Apr 21, 2008 | 06:13 PM
j9fd3s's Avatar
Community Builder
on an s5 all you need are the calipers, brake pads, and that little hard line
Old Apr 22, 2008 | 02:17 AM
ok so i have the s4 then what?
DerpyToast
14
Nov 23, 2024 05:19 PM
_Tones_
May 25, 2021 05:37 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
